One of the best reasons for going to FABTECH 2011 is the extensive schedule of educational seminars and presentations designed to give you insight into industry trends and advancements. As always, Miller and its ITW partners are proud to take part in these seminars, and we’ve put together here a preliminary list of key Miller-related sessions you should keep an eye out for.
FABTECH 2011 is taking place November 14-17 in Chicago at McCormick Place.
Educational Annual Program: Monday 11/14
Miller’s Bruce Albrecht will participate in an industry roundtable discussion of “Career Paths in Welding” from 11:30 am to noon and then again from 1:15 to 2:45 pm in room N131.
Educational Annual Program: Tuesday 11/15
Miller’s Rolando Sanchez and Paul Cleveland will give an educational reform presentation for welding educators from 1:00 to 3:00 pm in room N138.
8th Conference on Weld Cracking: Tuesday 11/15
Hobart Brothers’ Joseph C. Bundy will present “Understanding Weld Cracking in Steels” from 8:30 to 9:05 am in room N230B. Here’s a brief overview:
There is a great deal to be said about the consequences, the causes, and the remedies pertaining to weld cracking. In this presentation we will touch on all three and delve into the solidification and liquation cracking prevalent in hot cracking as well as the problems caused by diffusible hydrogen. The topics of pre- and postweld heat treat will also be examined.
Bruce Anderson from MAXAL will present “How to Prevent Cracking When Welding Aluminum Alloys” from 10:30 to 11:05 am in room N230B. Here’s a brief overview:
This presentation will examine the primary reasons for hot cracking to occur when welding the various aluminum alloys. It will evaluate the crack sensitivity associated with the various alloying elements that are added to aluminum and how we can use crack sensitivity curves to predict and thereby reduce the hot cracking potential of our welds. It will further discuss the importance of correct filler alloy selection and how the filler alloy/base alloy combination can be critical in the prevention of solidification cracking.
Tube and Pipe Joining & Inspection: Tuesday 11/15
Miller’s Jim Cuhel and Ron Halpenny of Graham Corporation will present “Regulated Metal Deposition (RMD™) Modified Short Circuit MIG and Pro-Pulse™ Pulsed MIG Welding Processes Advance Pipe Welding Performance and Productivity” from 10:30 am to 12:30 pm in room S503B. Here’s a brief overview:
Through a calm, stable arc and smooth metal transfer, Regulated Metal Deposition (RMD™) outperforms TIG and short circuit transfer MIG welding processes in pipe welding root pass applications by reducing rework and distortion, and providing process benefits such as faster travel speeds and the elimination of back purging on stainless steel.
What’s New in Power Sources Program: Wednesday 11/16
Miller’s Todd McEllis will present “Modern Power Source Technology that Drives Process Improvement” from 8:30 to 9:05 am in room N231. Here’s a brief overview:
The goal of the welding industry is no different than that of other industries – improve productivity, ensure consistent quality, and of course lower costs. It is difficult if not impossible to attain these goals without accurate real-time and historical weld process information. In the past, some companies have attempted to use “bolt on” equipment to obtain this type of information. Welding power source manufacturers have now begun to incorporate weld process and production management information into their product offering. This discussion will focus on how the information provided by this new generation of power sources can be used to increase productivity, improve quality, reduce costs, and better manage the overall welding operation. Miller’s Axcess power source will be used as an example.
Miller’s Jim Cuhel and Ron Halpenny of Graham Corporation will present “Controlled Short Circuit GMAW Process Competes Favorably with SMAW, GTAW” from 3:05 to 4:00 pm in room N231. Here’s a brief overview:
The combination of Regulated Metal Deposition, or RMD™, and the Pro-Pulse™ Pulsed MIG process Pro Pulse provides an efficient method of welding pipe from root to cap with one wire and one gas. The presentation includes a case study involving Graham Corporation, the world leader in engineered-to-order vacuum and heat transfer equipment. These processes have significantly reduced rework (down from 3.2 to 1.3%) and lead times. This includes faster travel speeds on root passes (between 6 to 12 ipm) and a 22% productivity increase over manual TIG. In summary, the described technology provides the following: it reduces rework on the root pass in pipe welding applications and distortion by reducing overall heat input in pipe welding applications. The need for back-purging in stainless pipe welding applications is also eliminated. Travel speeds are also increased.
We hope you attend some of these valuable presentations. For a glimpse at the entire schedule of educational seminars at FABTECH, click here.
