IE Series Header Induction Heating
IE Primary Image Induction Heating
IE Secondary Image Induction Heating
Induction Heating
Meet deadlines and protect your budget with ProHeat™ and ArcReach® induction heating. Unlike flame or resistance, induction turns the metal into its own heat source for fast setup, precise control, uniform temperatures and efficient heating that keeps jobs moving.
ArcReach Heater Application 569A1846
Accessories
Complete your induction heating setup with accessories designed for flexibility and efficiency. Whether you're managing heat, extending reach or adapting to unique jobs, the right components keep your operation running smoothly.
Induction Heating Comparison Heat Distribution
Induction Heating Comparison Original
Simpler. Faster.
With an induction heating system, the metal part you're heating actually becomes its own heating element. Easy to set up, induction delivers exceptional accuracy and efficiency, faster time-to-temperature and true temperature uniformity across the workpiece.
A Smart Investment
Reduce Injury
Removing open flames from the jobsite increases safety.
Reduce Inefficiencies
Your weld team can be your heating team.
Reduce Time to Heat
Your overall cycle can be up to 4x faster than flame or resistance heating.
ArcReach Heater Application 569A1364
Applications
  • Preheating and maintaining weld temperature
  • Hydrogen bake-out
  • Post-weld heat treatment (PWHT) up to 1,450° F
  • Shrink-fit processes
  • Various other applications which require heating
Watch Induction Heating in Action
The smarter way to preheat welding areas. It's time to trade in your torches and switch to induction heating.
Miller® Induction Heating Solutions for Faster & Safer Welding
Induction vs. Other Heating Methods
 Induction HeatingFlameResistance
Reduce InjuryExceptional
Only the part gets hot
Poor
Open flame causes burns and exposure to toxic fumes
Poor
Accidental touching can cause burns, broken pads can cause shocks
Reduce LaborGood
Fast setup/teardown
No operator required during heating process
Poor
Operator required to handle torch
Often requires fire watch
Poor
Slow and complex setup and teardown in many cases
Reduce InefficienciesGood
Easy to self-perform
Heating efficient with utility use
Poor
Most heat is wasted into the air
Inefficient with utility use
Poor
Bad electrical power factor causes inefficient use of utility
A lot of heat wasted in the process
Reduce Time to HeatGood
Heat is generated within base material
Focused heat over the entire part speeds heating process
Poor
Torch needs to be continually moved to heat entire part, resulting in slower heating speeds
Poor
Heat is generated in the element instead of the part
Unfocused heat results in slower heating speeds
“With the change to wire processes and induction heating rather than open flame, that same weld takes five and a half hours to complete — a 52% increase in productivity.”
Mueller
Senior Welding Engineer With TC Energy
Induction Heating App
Talk to an Induction Heating Specialist
Induction heating saves time and money and is designed with your crew in mind. Plus, it's easy to make the change.
