Easier to use products through auto-settings and better visibility.
Improve productivity with technologies that enhance efficiency and save you money.
Optimize your operation through advanced welding processes, training and weld data monitoring.
Insight Centerpoint™ has the ability to help identify missing welds and reduce costly mistakes.
Insight Centerpoint™ detects both under and over welding to identify possible failed parts and costly waste of filler metals and gas.
Insight Centerpoint™ detects potential weld defects and identifies them to be inspected and annotated.
The HMI guides the operator through a step-by-step sequence to insure components are welded to proper procedures and also shortens the learning curve for new operators.
Insight Centerpoint™ can track common reasons for weld cell downtime. This information can be used to drive continuous operational improvements.
History View provides valuable information to track parts and welds, along with totalization of arc time, wire & gas usage, downtime, and deposition.
Insight Centerpoint's™ relational database provides a permanent record of parts and welds produced, including weld signatures, weld report information and annotations for historical weld records.
Helps determine the cost of welding components and facilitates the evaluation of improvements made in the welding process.
Web browser interface with the Axcess E allows authorized employees to change configurations, check settings, define programs, update firmware, monitor basic functions, troubleshoot the system, and much more.
Insight Reporter™ provides preconfigured management reports and information that fuels continuous improvement and collects data from the entire fleet of Axcess® E systems through a Microsoft SQL database.
Axcess® E with Insight™ can leverage the power of factory networking or it can function in a standalone mode, depending on user preference.
Insight Centerpoint™ HMI provides an easy and intuitive way for operators to interface with the monitoring system. Visual interface provides step-by-step procedures, resulting in improved productivity and quality.
