Advancements in Pipe Welding Processes and Techniques | MillerWelds
Share
Take your pipe welding to a whole new level! Discover advances in pipe welding along with the benefits of the patented RMD Pro™ and Pro-Pulse™ weld processes on the new Pipe Welding Techniques video.
To view the videos online, please select the appropriate title from the segments listed below.  Order video content on CD
New Advances in Pipe Welding
Provides a brief summary of the benefits of RMD Pro and Pro Pulse. (Duration: 2 min. 54 sec.)
Preparation of the Pipe Joint
Provides a technical explanation of the steps required to prepare and tack weld pipe for RMD Pro (MIG Modified Short Circuit) welding. (Duration: 2 min. 24 sec.)
RMD on Carbon Steel Pipe
Provides a technical explanation of the techniques required to weld carbon steel pipe with the RMD Pro (MIG Modified Short Circuit) welding process 1G Rolled Position and the 5G Fixed Position.  (Duration: 4 min. 43 sec.)
RMD on Stainless Steel Pipe
Provides a technical explanation of the requirements to weld stainless steel (without backing gas) pipe with the RMD Pro (MIG Modified Short Circuit) welding process. (Duration: 2 min. 05 sec.)
Cap and Fill with Pro-Pulse
Provides a technical explanation of the techniques required to weld carbon steel and stainless steel pipe with the MIG Pro Pulse welding process in the 1G Rolled Position and the 5G Fixed Position (uphill and downhill travel). (Duration: 3 min. 06 sec.)
Published:
Archived
