AGCO Partnered With Miller
Over the past 25 years, AGCO has worked with Miller on custom programming and field testing numerous products. Given the long-standing partnership, they decided to reach out to the Miller team to ask for help.
Jeff Van Muyden, area manager of the AGCO weld department, recalls, “The first thing Miller did was ask a few questions about the problems we were having, and then they sent a team out. They took samples back to their facility and helped us come up with weld settings that would work for us."
Miller’s proposed solutions included implementing standardized weld parameters and investing in a new welder, a
Deltaweld® system, which would turn out to be more transformative for their team and their work than AGCO had hoped or expected.
The Deltaweld system, when paired with the
Intellx™ Elite feeder, comes equipped with a host of features, including advanced processes like
Versa-Pulse™ and a welding software and technology called
Insight Centerpoint™. Miller recommended Versa-Pulse for AGCO because it controls the focal area of the heat, providing a tighter arc that helps prevent stainless steel warping and burn-through due to low heat input, creates higher-quality parts and mitigates rework, all while facilitating faster travel speeds. Given the varied level of operator experience, Miller’s recommendation included AGCO continuing to leverage Centerpoint as a user-friendly guide for each weld. Centerpoint shows operators exactly how and where to fit-up the part and in what sequence to weld, along with automatically setting the parameters and showing the operator how to jig up the part, improving weld consistency, ensuring no welds are missed and maximizing operator efficiency.
AGCO took Miller’s suggestions into consideration and into the shop, where they conducted a blind test against the competition and ultimately concluded it was time to make a move to the Deltaweld system.
