Submerged Arc Welding Digital Series | Miller Welds | MillerWelds
We build for heavy duty performance.
Discover Innovative Solutions for Submerged Arc Welding
Miller® SubArc systems form your go-to family of products for high-performance, high-speed submerged arc welding (SAW). Whether you're looking for a traditional SubArc setup or more portable solutions, see how the SubArc Digital Series can augment your operation by minimizing downtime, lowering costs and fueling profitability.
Key Benefits
White clock icon on a blue background, representing fast welding performance.
Faster welds
Optimized arc control and digital precision reduce the need to make multiple weld passes, cutting down on the most time-consuming parts of the SAW process.
Wrench inside a gear icon on a blue background, representing seamless integration.
Easy to integrate
The modular system can seamlessly integrate with your existing setup, so you don’t need to start from scratch. Plus, ModBus® compatibility supports everything from remote control welding to full automation.
Finger pressing a button icon on a blue background, symbolizing a user-friendly interface.
User-friendly interface
Simple controls make it quick and easy to adjust parameters, set up parallel or tandem configurations.
Meet the Product Lineup
Miller SubArc systems are built with modular components that can adapt to your specific needs — perfect for upgrading your existing setup or scaling your operation.
Power Sources
As the foundation of the SubArc family, these power sources deliver digital control, modular design and proven reliability. With the capacity to handle submerged arc (SAW), electroslag (ESW) and other high-current welding applications, they support multi-wire tandem welding and paralleling of multiple power sources to maximize performance without compromising quality.
new
SubArc Hercules™
The new SubArc Hercules system can slash your weld time by 30% on average. Marking a major advancement for the submerged arc welding process, our leading-edge technology uses a secondary power source with an innovative torch that enables resistive conditioning of the specialized wire. This delivers much higher deposition rates, reducing the number of passes needed without compromising the weld quality you're used to.
The modular components of the SubArc Hercules also make it easy to integrate the system into your existing setup so you can get the exact capabilities you need.
An innovative torch that enables a higher metal deposition by preheating the wire before reaching the arc.
Mobile Systems and Tractor Packages
These versatile, field-ready solutions allow you to bring the power of the SubArc family wherever you work.
Accessories
Further customize your SubArc setup with these performance-enhancing tools.
Resources
Check out the resources below to learn more about how the SubArc welding systems can speed up your operations. Learn more about the technology, training, support and onboarding — or see it in action.
Additional Resources
Grouped tools icon on blue background representing components and accessories.
SubArc Systems
Explore SubArc Systems
White Hobart Filler Metals icon on blue background.
Hobart® Filler Metals
Explore Hobart® Filler Metals
Cloud download icon on a blue background, symbolizing software updates and digital accessibility.
Software Updates
Explore Software Updates
Flip the Switch to Higher Deposition
See how Komatsu improved weld quality and efficiency by integrating the SubArc Hercules™ system at its Longview, Texas facility.
See It to Believe It
Get a closer look at the SubArc Hercules and the rest of the SubArc systems by booking a demo with one of our experts, and see firsthand how our innovative solutions could enhance your operation.
Talk To An Expert
