Best XMT® Welders for Your Jobsite: Power Source Comparison | MillerWelds
Which XMT® Is Right for Me? | Compare Welding Power Sources for Your Jobsite
Share
Discover which XMT® power source best fits your jobsite, workflow and application needs with this comparison guide.
Hero image of a welder using an XMT® power source in a shop with the image copy “Which XMT® Is Right For Me?".
Match your power source to your operation
Whether you’re working in a fabrication shop, on a lift or across a sprawling jobsite, the power source you choose directly impacts productivity, safety and consistency. Selecting the right one starts with understanding your working conditions, the workpiece requirements and your operation’s specific workflow. The XMT family of welders — known for their reliability, versatility and industrial-grade performance — has evolved to meet the varied demands of operations across industries. Let’s take a closer look at the different options to help you identify which machine best fits your needs.
XMT® 400:
For welders who need compact multiprocess capabilities for fabrication and training
When your operation demands flexibility without sacrificing footprint, the XMT 400 multiprocess welder delivers. As the most compact industrial-grade welder in the lineup, it’s purpose-built for fabrication shops and manufacturing floors where space is limited but performance expectations are high. Instead of juggling multiple machines for TIG, MIG, stick or gouging, the XMT 400 consolidates those capabilities into one powerful, scalable unit, simplifying your setup and freeing up valuable floor space. It’s also an ideal solution for training environments, offering educators a single, intuitive platform that supports a wide range of skill levels and unlocks a wide range of advanced processes with Intellx™ wire feeder compatibility.
Graphic outlining the advanced processes that are unlocked with Intellx™ wire feeders.
While all Intellx feeders offer improved control, consistency and performance, pairing the XMT 400 with the Intellx Pro enables pulse programs such as Accu-Pulse®. With the Intellx Elite, operators gain access to the full suite of advanced processes, including Regulated Metal Deposition (RMD®), Versa-Pulse™, Accu-Pulse and (High Deposition) HD MIG. Additionally, both of these feeders feature EZ-Set Technology, which simplifies weld parameter setup for faster, more confident starts. These advanced capabilities widen the operator window, resulting in more consistent welds and less rework while making it easier for newer welders to produce higher-quality welds. That’s a major advantage in manufacturing environments where turnover is high and training time is limited.
Key features:
  • Multiprocess Capability: DC TIG, stick, MIG, gouging
  • Auto-Line™ Technology: Plugs into any power source (208V–575V, single- or three-phase)
  • Lightweight and Compact: Saves square footage and weighs only 70 pounds
  • Intuitive Interface: Familiar controls reduce training time and help operators get right to work
  • Scalability: Compatible with your existing 14-pin and volt-sensing feeders as well as ArcConnect
  • Arc Control and LED Indicators: Provide real-time feedback and enhanced visibility on the power source
  • Lower Maintenance Costs: Designed for easier serviceability with reduced maintenance costs
Built for: Indoor, under-roof environments like manufacturing, fabrication shops and classrooms
Graphic of the XMT® 400 with feature icons.
XMT® 400 ArcReach®:
For outdoor jobsites where portable, compact power and remote control are needed
For welders working outdoors or on elevated jobsites, managing long control cables isn’t just inconvenient; it’s a safety risk. Tangled or damaged cables can lead to trip hazards and costly downtime. The XMT 400 ArcReach eliminates the need for control cords by enabling full remote control at the weld site using existing weld cables. ArcReach technology allows operators to adjust weld parameters directly at the wire feeder or remotely, boosting efficiency and reducing downtime and jobsite risks. This enhances productivity by saving up to 250 hours per operator annually and improves safety by reducing trips across busy or large jobsites. With a streamlined interface and industry-leading arc performance, operators can make precise adjustments without leaving the weld joint.
Image of a welder using the XMT 400 ArcReach® on a ship in a shipyard.
On top of these benefits, the XMT 400 ArcReach stands out for its 400-amp output at a 60% duty cycle, delivering unmatched power and precision as the lightest, smallest machine in its class. Its heavy-duty build ensures consistent performance on demanding jobs, while a streamlined interface, multiprocess capabilities and fleet-friendly design allow crews to work faster with fewer machines, making it a dependable, high-productivity solution for large sites and lean teams.
Key features:
  • ArcReach® Technology: Remote control via weld cables — no control cords needed when paired with any ArcReach wire feeder or accessory
  • Adjust While Welding (AWW™): Make changes without extinguishing the arc
  • Cable Length Compensation (CLC™): Compensates for voltage drop over long cable runs
  • Auto-Line™ Technology: Automatically adapts to any input voltage (208–575V, single- or three-phase)
  • Auto-Process Select™: Automatically detects electrode polarity and ArcReach accessory type to set the correct welding process
  • Improves Safety: Reduces trips and hazards on busy jobsites
Built for: Tough outdoor jobs in field construction, structural steel, shipbuilding and rental fleets
Graphic of the XMT® 400 ArcReach® with feature icons.
XMT® 650:
For welders who need high amperage to tackle heavy-duty applications
When you're welding massive workpieces, there’s no room for compromise. These kinds of jobs demand high deposition rates, thicker wire diameters and sustained power output. They also often require multiple passes, precise heat input control and adherence to strict structural codes. The XMT 650 delivers the amperage, duty cycle and gouging power needed to meet these challenges head-on with up to 650 amps of output, allowing operators to remove more material per pass. This makes it ideal for heavy industrial environments where power and precision are non-negotiable and performance is paramount. Engineered for permanence and peak output, this machine supports the kind of work where every weld carries weight.
Image of a welder using the XMT 650 in a shop.
Key features:
  • Arc Control: Adjusts inductance to optimize MIG arc performance or dig control for stick, ensuring optimal results across processes
  • Auto Remote Sense™ (ARS): Simplifies setup by automatically detecting remote connections, eliminating the need for manual switching
  • High Deposition Performance: Meets structural codes and productivity demands
  • Stationary Setup: Ideal for environments where portability isn’t a priority
  • High-Amperage Wire Capability: Handles large-diameter wires, large gouging carbons and stick rods with an output range of up to 815 amps
Built for: Heavy-duty indoor manufacturing and fabrication environments with traditional feeders/accessories
Graphic of the XMT® 650 with feature icons.
XMT® 650 ArcReach®:
For large-scale outdoor projects where high power and remote control are needed
For rugged environments and large-scale industrial work, the XMT 650 ArcReach delivers the muscle of the XMT 650 with the added advantage of ArcReach technology. On expansive jobsites like bridge and beam construction, shipyards and seismic structural welding, control cables can cause some significant challenges: they’re easily damaged, expensive to replace and pose safety risks when stretched across active zones. This is where the remote control capabilities of ArcReach shine at the weld site.
Designed specifically for ArcReach power source models, the ArcReach 16 wire feeder is compatible with the XMT 650 ArcReach system. It supports large-diameter wire and enables seamless switching between welding and gouging without the need to change leads. Also, the ArcReach 16 offers integrated field rollers, spool covers and cable holders for enhanced mobility and durability.
Image of a welder using the XMT 650 ArcReach® on a steel beam structure outdoors.
Key features:
  • Cable Length Compensation (CLC™): Ensures the voltage set at the power source is accurately delivered at the weld site, even across long cables
Built for: Large outdoor industrial environments, including bridge building, shipyards, seismic structural steel fabrication/erection and general construction
Graphic of the XMT® 650 ArcReach® with feature icons.
Compare XMT® models at a glance
Whether you’re welding in the shop or out in the field, the XMT family offers scalable solutions to match your power, portability and process needs. Here’s a side-by-side look at how each model stacks up.
Model Environment Portability Processes Versatility Industries Applications
XMT® 400 Indoor Compact, stationary or with MIGRunner cart Air Carbon Arc Cutting and Gouging (CAC-A), Flux-Cored (FCAW), MIG (GMAW), Multiprocess, Pulsed MIG (GMAW-P), Regulated Metal Deposition (RMD®), Stick (SMAW), TIG (GTAW) General manufacturing, fabrication, transportation, education, pipe fabrication General fabrication, truck/trailer fabrication, sheet metal fabrication, light-gauge tube and sheet, pipe fabrication, repair shops
XMT® 400 ArcReach® Outdoor Mobile Air Carbon Arc Cutting and Gouging (CAC-A), Flux-Cored (FCAW), MIG (GMAW), Multiprocess, Pulsed MIG (GMAW-P), Regulated Metal Deposition (RMD®), Stick (SMAW), TIG (GTAW) Construction, shipbuilding, power generation plants, rental fleets, fabrication Maintenance repair operations (MRO), boat/yacht fabrication, field welding, industrial welding, structural welding
XMT® 650 Indoor Stationary Air Carbon Arc Cutting and Gouging (CAC-A), Flux-Cored (FCAW), MIG (GMAW), Multiprocess, Stick (SMAW), Submerged Arc (SAW), TIG DC (GTAW-DC) Heavy manufacturing and fabrication, railcar manufacturing, earth-moving equipment manufacturing Heavy manufacturing and fabrication, SubArc, gouging
XMT® 650 ArcReach® Outdoor Stationary Air Carbon Arc Cutting
 and Gouging (CAC-A), Stick (SMAW), TIG (GTAW), Submerged Arc (SAW), Flux-Cored (FCAW), MIG (GMAW) General construction, heavy manufacturing, shipbuilding, refineries and foundries Structural steel fabrication/erection, maintenance repair operations (MRO), pressure tank/vessel fabrication
Find the right welding power source — wherever the job takes you
When you need a power source that works as hard as you do, the XMT delivers the industrial-grade performance, process versatility and reliability welders count on. Whichever model is right for you, you’ll get the trusted performance and innovation that make your welds consistent and operation efficient. Explore our selector tool to find the right XMT solution for your needs.
Related Products
Published:
