STEP FIVE:
Frame mounts for the rear of my car are not as wide or thick as those for the front, so they will be built differently. I used the same 3/16" flat plate and TIG welded the corners. Since I had a hole already in the frame, I am attaching it using two 3/8" rivet nuts on each side. You can do that or attach it just like we did in step 4.
