A New Era of Portable Welding Machine Technology
The Miller Venture 150 S battery powered welder has changed the way businesses like Bezates Construction, PCL Construction, Goodine Welding, Sabel Mechanical, Eaton Performance and Basset Mechanical approach jobs. With its compact and rugged design, swappable batteries, and dependable weld quality, the Venture 150 S helps welders complete more work in less time without sacrificing performance.
“It’s 10% of the time that it would be dragging everything else out,” said Nick Bezates, who has used the Venture on multi-story hot tap installations. “A huge percentage of the job is just setup and cleanup time—and the Venture completely eliminates that.”
At under 27 pounds and with swappable batteries that can weld up to eight 1/8-inch rods per charge, the Venture gives welders the freedom to go anywhere that power can’t—no cords, no generators, no hassle.
“You can carry it by yourself, up a ladder, up scaffolding,” said Mack Johnston from PCL Construction. “Time savings is cost savings in this industry—and this tool saves both.”
