Engineered for Welding The Miller Venture 150 S Redefines Battery Powered Welding | MillerWelds
Engineered for Welding: The Miller® Venture™ 150 S Redefines Battery Powered Welding
Share
With a strong background in high-performance battery systems, Eric Rask has helped lead the development of the Venture 150 S — a welder that exemplifies Miller’s “Engineered for Welding” philosophy. This approach ensures the battery system is built to meet the unique demands of welding, delivering consistent high power, durability, and safety. The result is a portable welding solution that maximizes productivity and flexibility without compromising performance.
Eric Rask breaks down what “Engineered for Welding” means — and why it matters for battery-powered welding performance.
Battery Powered Welding Technology
As battery technology continues to improve and evolve, high capability battery powered tools and equipment are being utilized across an increasing range of jobs-to-be-done and application areas. Given Miller’s history of technological innovation it is no surprise that this evolution has reached welding – specifically, the new Venture 150 S, a battery powered welding solution Engineered for Welding. The Venture 150 S makes it easy to tackle a variety of jobs without needing to setup or worry about power cables – saving you time and money.
Compared to many other applications, welding represents a particularly demanding set of battery performance and capability requirements – this is why the “Engineered for Welding” philosophy was the foundation for the Venture 150 S battery pack design. To produce a high-quality arc, a welder requires high levels of continuous power supplemented by very high power transient pulses for starting and maintaining the arc. This power delivery must be done across a range of demanding environmental and usage conditions, always with a focus on safety, productivity, and performance.
Building on this foundation, the design of the Venture 150 S battery pack and charger used a multi-layered design approach. As with any battery pack, a primary performance driver is the selection of battery cells. For the Venture 150 S’s lithium-ion battery pack, a Lithium Iron Phosphate (LFP) cell chemistry was chosen for its well-established mix of increased safety, enhanced durability, power capability, and low resistance. Moreover, a specific LFP cell with excellent power density and low resistance was selected to maintain consistent performance across a range of usage and environmental scenarios.
Beyond the cells themselves, significant engineering effort was also put into the software and hardware that comprise the Battery Management System (BMS). The BMS further enables the safety, durability, and performance of the pack, providing protection and optimal operation across a wide range of conditions. Together, the LFP cells utilized in the pack combined with the engineering effort behind the pack’s BMS enable optimized welding performance and over 1000 full-charge cycles under typical use cases and with proper care.
Another important design feature of the Venture 150 S battery pack is its swappable architecture. By disconnecting the pack from the welder, multiple batteries can be used, enabling rapid changeover, more productivity, and the flexibility to get the job done. The lightweight batteries can be easily carried into the field, allowing for welding anywhere a job requires. Additionally, the charger for the Venture battery pack provides selectable fast-charging which recharges a pack to 95%+ in under 30 minutes (under typical operating conditions) – all while utilizing a standard 120V electrical outlet.
Given the foundation of safety, performance, versatility, and productivity represented in the “Engineered for Welding” philosophy, the Venture 150 S battery pack enables more work with less setup and downtime, saving you time and money.
Published:
