CSD Series Header Battery-Powered
CSD Primary Image Battery Powered
CSD Secondary Image Battery Powered
Battery Powered
No power? No problem. The Venture™ family of battery powered welders features two compact, battery-powered stick/TIG welders designed for true portability and quick setup, with reliable performance in tight spaces and remote field environments.
Technology and Features
Lightweight and powerfully convenient, our portable battery welders’ advanced engineering keeps you welding all day.
Save Time
Faster setup and pack-up saves up to 250 hours annually — that’s more time for welding.
Compact Design
Light, convenient and easy to carry between jobsites.
Engineered Specifically for Welding
Swappable battery packs so you can weld all day.
Reliable Output
100% duty cycle at maximum output.
Process Capabilities Venture™ 150 S Venture™ 150 T
Stick X X
Stick: 6010 Stick Mode X X
TIG: Lift-Arc Starts X X
TIG: High-Frequency Starts   X
TIG: QuietPulse™   X
Portable: 27 lbs. X X
Swappable, Rechargable Batteries Engineered for Welding X X
Stick-Stuck X X
Hot Start™ X X
Flow-Through Dinse   X
6-Pin Connection   X
Integrated Gas Valve   X
Pulse (0-150 PPS)   X
Adjustable Pre and Post Flow   X
Venture™ 150 S Testimonial: Bassett Mechanical
“It’s lightweight. It’s very user friendly. It’s easy to use the battery swap out mechanism. It’s quick. I’ve got nothing but positives to say about it.”
Scott Herzfeldt
Bassett Mechanical
“The Venture 150 T is the ideal setup. Once you get your hands on this machine and use it, you’re going to fall in love with it.”
James Taylor
Standard Maintenance
Venture ™ 150 T Testimonial: Smalley Mfg, Standard Maintenance and Stiltz Iron
Venture 150 S - Portland 15
Venture™ 150 S
The Venture 150 S is a lightweight and compact battery powered stick/TIG welder with swappable battery packs engineered specifically for welding.
