DIY Welding Project: Planter and Flower Vase [Guide] | MillerWelds
Share
Looking for your next DIY welding project? Josh Welton gives step-by-step instructions on how to weld a DIY planter and flower vase.
DOWNLOAD PROJECT PLAN
SKILL LEVEL:
Beginner +
TIME COMMITMENT: One day or less
Here's what you'll need to get started.
TOOLS AND MATERIALS
Miller® Dynasty® 280DX Multimatic® 220 AC/DC or another TIG machine
Angle or die grinder (with a cutting wheel), metal cutting band saw, or plasma cutter
Grinder
(with flap disc, wire wheel, and sanding discs)
Thick stainless steel and mild steel plate
 Copper sheet
Silicon bronze rod (SiB)
Stainless steel rod
Optional Equipment/Tools
Hammer
Square and/or machinist's block
Quick clamps
Marker
WARNING: READ AND FOLLOW ALL LABELS AND THE OWNER'S MANUAL.
STEP BY STEP
This planter and flower vase is a cool DIY welding project that will add character to any home. Follow these steps for how to weld your own using a TIG welder.
Cutting metal with a cutting wheel
STEP ONE:
Measure and cut the stainless steel and mild steel plates to size. In this case, the dimensions are 4"x4" for the base and 4"x7" for the sides. Then cut two pieces of copper 1" wide and over 8" long. Leave a little extra length on the copper for fit-up. Once you’ve laid out the cut lines, use your cutting wheel, saw or plasma cutter to cut the steel. Clean up the edges with a flap disc.
Clamp holding four pieces of metal in rectangular shape
STEP TWO:
Square up the sides in pairs. Use a 90° block of some sort with a clamp to hold them in place, then tack them together. Put the mild steel sides opposing each other, then fit the stainless steel pieces on either side of them. Make sure the bottom and the sides are all tacked together, and keep fit-up in mind for a nice corner to weld.
closeup of welder TIG welding metal pieces together
STEP THREE:
Clean the edges with a wire wheel or brush. Weld the bottom four edges using the stainless filler. Take care to wrap the corners; those are the most problematic spots for leaks.
STEP FOUR:
Now it’s time for the silicon bronze rod. Do any welding you’re going to do first, because you can braze SiB over ss, but it’s not fun trying to weld with mild or stainless filler metal over the silicon bronze. TIG braze all the vertical seams. I’m using DC on these joints, but you can also TIG braze using AC. Dealer’s choice.
STEP FIVE:
Place the copper strip about 1" up from the base of the vase. Bend it by hand to make the corner. The silicon bronze used to be a style choice, but now it’s a necessity. We’re joining dissimilar metals: copper to both stainless steel and mild steel. Line up one end of the first copper strip with a corner of the vase, square it up and tack the strip to the steel, working your way across. Copper likes to move around when heated, so you’ll have to keep clamping and hammering it to stay in line and tight to the steel. Repeat this process for the second strip, just place it 2" up from the base and opposite of the first piece.
TIG welding copper to steel
STEP SIX:
Begin laying down SiB beads on the edges of the copper to the face of the steel. Again, take your time and run short beads; you’ll have to continue to hammer and clamp the copper to keep it flat. The characteristics of the materials are very different, so be patient. If you leave too much of a gap under the copper, you’ll blow through it. Keep it tight to the steel as you move around with the filler and the TIG torch, leaving no edge untouched.
Adding TIG beads around top edges of metal planter
STEP SEVEN:
To finish off the welding/brazing, run little beads around the top edges of the vase. It rounds them off, taking away any sharp corners, and it adds a little style.
completed empty metal planter
STEP EIGHT:
Make sure it doesn’t leak! Add some water while keeping the outside dry. Set it on a dry surface, and  let it sit while inspecting all the edges and the corners. If it leaks, you’ll need to grind out that spot and weld/braze it again.
two completed metal planters with plants in them
STEP NINE:
Clean the outside edges with a light wire wheel or sanding disc if you’d like. If not, just wipe the shop dust off of it, set it in or around your living space, and add a plant or flowers!
About Josh Welton
Josh Welton headshot
Josh Welton, owner/operator of Brown Dog Welding LLC — a fabrication and art studio in Detroit — is an established welder, fabricator, teacher, artist, writer, social media influencer, podcast host, entrepreneur and automotive enthusiast. He is a contributing writer to TheFabricator.com, The Welder Magazine and DodgeGarage.com.
Follow Josh at BrownDogWelding.com or on Instagram @WelderAssassin.
Get More Project Ideas & Plans
Feeling inspired? Check out our project page for more DIY welding projects, including step-by-step guidance, videos and downloadable plans.
CHECK IT OUT
Published:
