Why tungsten matters in TIG welding
One of the reasons TIG welding is favored for sensitive welding applications is because it gives the welder exceptional control. This precision comes from an electric arc streaming from a tungsten electrode in the torch. To enhance that performance, welding engineers have developed ways to tailor these electrodes for specific applications by adding small amounts of exotic elements to the tungsten — each variation marked by a color band at one end.
In the early days of TIG welding, there were only two types of tungsten that were commonly used: pure tungsten for aluminum and magnesium, and 2% thoriated tungsten for everything else. While these options worked well for generations, ongoing research and development introduced a wide range of tungsten electrodes, each with unique properties and advantages. For beginners, navigating these options can feel overwhelming. In this article, we’ll break down the most widely used types and give you the insight you need to choose the right tungsten electrode for your welding project.
Understanding tungsten electrode types
Pure tungsten (green)
Pure tungsten was the first electrode used when TIG welding was introduced in the 1940s. TIG welding was developed to efficiently join aluminum and magnesium alloys, and pure tungsten was a good choice because it has the highest melting point of all metals. With the transformer-based power sources of that era, pure tungsten worked well for AC welding, which is standard for aluminum and magnesium.
Historically, welders prepared the tungsten by “balling” the tip — melting it briefly in reverse polarity so it solidified into a smooth, shiny ball. This created a wide, stable arc and allowed the electrode to carry high current without contaminating the weld puddle.
However, as the industry shifted from transformer-based to modern inverter power sources, the need for balling electrodes became unnecessary, and pure tungsten electrodes were replaced by blends that deliver superior arc stability.
Thoriated tungsten (red)
For DC welding — used on all metals other than aluminum and magnesium — adding a small amount of thorium (typically 2%) to the tungsten electrode was a game-changer. This improved arc starts and increased the electrode’s current carrying capacity, making thoriated tungsten the go-to choice for decades.
Like pure tungsten, thoriated tungsten has also fallen out of favor with modern welding equipment for two key reasons:
- Performance: Newer electrode types offer better compatibility with inverter technology.
- Safety: Thorium is slightly radioactive, and handling thoriated electrodes poses health and environmental risks at elevated exposure levels.
For more details on safe handling, consult the AWS Safety and Health Fact Sheet on Thoriated Tungsten Electrodes.
Lanthanated tungsten (blue)
Lanthanated tungsten has become one of the most popular choices for TIG welding — and for good reason. The 2% lanthanated tungsten (color-coded blue) is a true all-purpose electrode. It delivers excellent arc starts, handles high current without spitting and maintains a stable arc at both high and low amperage. Best of all, it works on all metals.
Ceriated tungsten (gray)
2% ceriated tungsten (gray) is another versatile option, especially for low- and medium-current applications. It offers good arc start and restart characteristics with no spitting, making it a reliable choice for welding all types of metals. If you often work at low amperage, this electrode is worth considering.
Rare earth tungsten (chartreuse)
Rare earth tungsten (chartreuse) stands out for its exceptional low-current arc starting performance. It works on all metals and is often the preferred choice for automated welding.
Zirconiated tungsten (white)
Zirconiated tungsten (white) is good for welding aluminum and magnesium alloys. It offers better arc stability and starting performance than pure tungsten, along with high current-carrying capacity, making it a solid choice for these specific applications.
Choosing the right tungsten electrode size
The next step is choosing the right size of tungsten for your application. Electrode diameters affect both arc starting and current capacity, and there are several things to keep in mind:
- Diameter range: Tungsten electrodes come in a wide range of diameters — from .020-inch up to ¼-inch.
- Match the diameter to the current:
- Use a larger diameter for higher amperage jobs.
- Use a smaller diameter for easier arc starts at very low amperage settings.
- Common choice: For most general work, a 3/32-inch diameter electrode is a versatile option. It handles light-gauge sheet metal and can weld metals ¼-inch thick or more without issues. Length: The standard length for tungsten electrodes is 7 inches. For working in tight spaces, you can cut electrodes, allowing a shorter back cap to be used on the torch.
How to prepare and sharpen tungsten electrodes
Proper preparation is essential for stable arcs and clean welds. Here’s what you need to know about cutting, shaping and maintaining tungsten electrodes.
Cutting tungsten electrodes
Start by cutting the electrode correctly to avoid hidden fractures that can cause an erratic arc.
- Use an abrasive cutoff wheel or the corner of a grinding wheel.
- Avoid using a wire cutter or bending to break — this can create micro-cracks that can compromise performance.
Point angle and arc shape
Tungsten electrodes usually come with blunt ends that need to be sharpened before use. The angle of the point determines the shape of the arc that streams from the electrode. There is an inverse relationship between the electrode point angle and the arc:
- Sharp point: Creates a wide puddle, ideal for edge-welding thin materials.
- Blunt points: Produces deep penetration, best for thicker materials.
For very high-amperage welding, it can help to grind a small flat at the tip of the tungsten electrode. This will help prevent the electrode from spitting small particles into the workpiece.
Grinding tips for stability
While there are specialized tools for sharpening tungsten electrodes, you can achieve excellent results with a stone, belt or disc grinder. To avoid contaminating the electrode, always use a grinder dedicated to tungsten. Make sure all grinding scratches run parallel to the electrode centerline — angled or spiral grinding scratches can cause an unstable arc.
Avoiding contamination
Electrode contamination is common and can compromise weld quality. It typically occurs when
- The tip is accidentally touched to the molten puddle.
- The filler rod contacts the hot electrode.
- Impurities from the base metal transfer to the electrode.
To maintain a clean arc, ensure the electrode is free from any contaminants. Replace it immediately if contamination occurs and keep several pre-sharpened electrodes handy for quick swaps as you weld.
Key takeaways
Selecting the right tungsten electrode and preparing it properly can make a big difference in weld quality, arc stability and overall efficiency. From understanding tungsten types to choosing the correct size and sharpening techniques, each step helps you achieve a cleaner, more precise weld.
When in doubt, start with a good all-purpose electrode like a 3/32-inch diameter 2% lanthanated tungsten. Pair that with proper grinding and contamination prevention, and you’ll maximize electrode life while ensuring consistent, high-quality results on every weld.
