DIY Welding Project: Custom Bicycle Sculpture Art | MillerWelds
Share
Join Josh Welton, owner of Brown Dog Welding LLC, as he guides you through the process of creating a mini bicycle sculpture. In this step-by-step tutorial, you'll learn how to use the versatile Miller® Multimatic® 220 AC/DC multiprocess welder to bring your DIY metal art project to life.
Download Project Plan
SKILL LEVEL: Beginner/Intermediate
TIME COMMITMENT: 4 hours
Here's what you'll need to get started.
Tools and Materials
chop saw iconChop saw
wire cutter iconWire cutters
needle nose pliers iconNeedle nose pliers
vise iconVise
pneumatic die grinders Pneumatic die grinders (straight and right angle) with cut-off wheel, wire wheel and sanding discs
hammer icon<hammer<></hammer<>
TIG rod icon1/8", 3/32" and 1/16" TIG ER70S-6 rod
wall tubing icon
Short length of 2" diameter, 1/8" wall tubing
hex head bolt icon
One 5/16" hex head bolt, any length
washer icon
One 5/8" washer
nuts icon
Two 3/8" nuts
tubing icon
2" of 1/4" diameter tubing with an inside diameter of more than 1/8"
thick steel icon
One small piece of 1/4" thick steel, about 1 3/8" long and 1/2" wide. (This will be welded and ground on to create a proper seat shape.)
cold chisel icon
Cold chisel
welding helmet icon
Miller® Digital Infinity™ welding helmet
welding gloves icon
Miller TIG gloves
welding jacket icon
Miller welding jacket
safety glasses icon
Safety glasses
Step by Step
step 1
STEP ONE:
Find a reference photo in the general scale you’re going to be building. Use this scale as a base but adjust parts of the bike as needed to achieve the desired look. Draw the side profile of the bike on the weld table using a Sharpie.
step 2
STEP TWO:
For the wheels/tires, use a chop saw to cut two 0.30-inch pieces from 2-inch tubing. A cut-off wheel or chop saw can also be used. Sand down the rough edges and remove any mill scale with a wire wheel. To create an aggressive tread, weld small bumps in two rows around the outside surface of the tubing. Finish the pieces to ensure there are no sharp edges.
step 3
STEP THREE:
For the main frame and foam cushion, use 1/8-inch filler rod for thicker parts and 3/32-inch rod for thinner parts. Shape the rod using a drawing or picture as a guide. Cut a 1-inch piece off the 1/4-inch tubing, clean the edges and slip it onto the top tube. Weld the frame together, ensuring it captures the top tube.
step 4
STEP FOUR:
Use 3/32-inch rod for the rear posts and front forks. Cut two 3 1/2-inch lengths and bend them in the middle to form a long U shape to fit around the bike wheels. Trim as needed to fit the bike. Weld these pieces to the main frame and wheels, using weights or scrap metal to balance the bike.
step 5
STEP FIVE:
For the bottom rear posts, cut two 1 1/4-inch pieces of 3/32-inch rod. Add width to the front by welding a 1/2-inch piece of 1/8-inch rod in the middle, then join it to the frame. Weld two 3/8-inch nuts to the inside of the rear wheel to create a hub/sprocket look.
step 6
STEP SIX:
For the main sprocket, use a 5/8-inch steel washer. Use a cold chisel and hammer to shape the edges to resemble a sprocket. Next, weld it to the bottom of the seat tube, ensuring there is enough room in the center of the washer to feed in the 3/32-inch rod that will be bent into the shape of the pedals.
step 7
STEP SEVEN:
Refer to the photos to shape the 3/32-inch rod for the pedals. Feed the bent rod through the main sprocket and center it before welding it to the frame. Balance the bike upright, place a piece of metal under one side of the pedal and cut two pieces of 3/32-inch rod to the length of the last bend. Weld one piece to each side of the pedal rod.
step 8
STEP EIGHT:
For the headset/stem, cut the hex head off a 5/16-inch bolt, sand it to resemble a headset, and create a groove for the handlebars. Weld the handlebars to the headset and sand it smooth.
step 9
STEP NINE:
For the front handlebars and cushion, draw the desired form and bend 3/32-inch rod to fit. Cut another piece of 3/32-inch rod to fit between the handlebars. Cut the 1/4-inch tubing into a 7/8-inch piece, clean the sharp edges and insert the 3/32-inch rod. Weld the bar in place so the cushion spins like on old BMX bikes.
step 10
STEP TEN:
For the seat, use a 1/4-inch chunk of steel. Shape it by grinding and welding as needed or use a thicker piece and cut it to shape. Once it resembles a bike seat, weld it to the top of the seat post.
step 11
STEP ELEVEN:
Form the chain using 1/16-inch rod. Shape it into an oval, wider at the main sprocket and narrower at the rear sprocket. Weld it to the bike.
step 12
STEP TWELVE:
Finish the bike by sanding and cleaning as you build. Once complete, go over it with light sanding and a wire wheel to smooth it out. Decide whether to fasten it to a base, paint it, clear coat it or leave it raw.
Josh Welton headshotJosh Welton, owner of Brown Dog Welding LLC in Detroit, is a welder, fabricator, artist, writer and content creator. Since 2014, he has contributed to TheFabricator.com and The Welder Magazine and received the WEMCO/AWS Foundation Excellence in Welding Award. Josh's work includes fabricating military prototype vehicles and welding on battle-damaged tanks in Iraq. His sculptures, known for their automotive and industrial themes, are highly sought after. Josh and his wife, Darla, co-founded the Still Building America initiative to promote skilled trades and host welding workshops in their Detroit shop.
Published:
