Spool Gun Hookup Chart | MillerWelds
Spool Gun Hookup Information
Machine Serial Number Effective Spool Gun Adapter Needed
Millermatic® 35/90/120/130 XP/150/Challenger™ (172) All Serial Numbers Spoolmate™ 185
Spoolmate™ 3035
SGA-100 #043856
Millermatic® 135/175/140/180 All Serial Numbers Spoolmate™ 3035 SGA-100 #043856
Millermatic® 140/180/141/190/, Passport® Plus All Serial Numbers Spoolmate™ 100 Series
Direct Connect;
For the Millermatic 140/180, prior to serial #LH210051N, use SGA-100 #043856
No spoolgun solution available for the Millermatic Passport, must upgrade to the Millermatic Passport Plus.
Not compatible with Spoolmate 150
Millermatic® 185 Prior to KH376829 Spoolmate™ 185
Spoolmate™ 3035
Retrofit Kit #186871 &
Kit #207642
Effective with KH376829 Kit #207642
Millermatic® 211 Auto-Set with MVP™/211
Spoolmate™ 150 Series
Direct Connect
Millermatic® 200 Prior to JJ407380 Spoolmatic® 1 (N/A) Direct Connect
Spoolmatic® 3 (N/A) Kit #042236
Spoolmatic® 15A
Spoolmatic® 30A
Spoolmate™ 200 Series
Kit #042236 & WC-24 #137549
Effective with JJ407380 Spoolmatic® 1 (N/A) WC-1A (N/A)
Spoolmatic® 3 (N/A) Direct Connect
Spoolmatic® 15A
Spoolmatic® 30A
WC-24 #137549
Millermatic® 210/Pulser (included spool gun)/212 All Serial Numbers Spoolmate™ 3035 Direct Connect
All Serial Numbers Spoolmatic® 15A
Spoolmatic® 30A
Adapter cable #195287
Millermatic® 212 Auto-Set All Serial Numbers
Spoolmatic® 15A
Spoolmatic® 30A
Direct Connect
Millermatic® 255 All Serial Numbers
Spoolmatic® 15A
Spoolmatic® 30A
Direct Connect
Millermatic® 250/Vintage All Serial Numbers Spoolmatic® 15A
Spoolmatic® 30A
10-Pin Module #043084
Millermatic® 250X/251/300 with Meters/350/252 All Serial Numbers Spoolmatic® 15A
Spoolmatic® 30A
Direct Connect*
* The Millermatic 350 does not work with the Spoolmate 200
Millermatic® 300 without Meters All Serial Numbers
Spoolmatic® 15A
Spoolmatic® 30A
WC-24 #137549
Millermatic® DVI™ All Serial Numbers
Spoolmate™ 3035
Kit #207642
All Serial Numbers Spoolmate™ 200 Series Kit #207642 and Adapter cable #195287
Millermatic® DVI2™ All Serial Numbers
Spoolmate™ 3035
SGA #043856
Multimatic™ 200 Prior to MF364047N Spoolmate™ 100 Series
Direct Connect
Effecticve MF364047N Spoolmate™ 100 Series
Spoolmate 150 Series
Multimatic™ 215
Direct Connect
Multimatic™ 220 All Serial Numbers Spoolmate™ 100 Series
Direct Connect
Multimatic™ 255
All Serial Numbers
Spoolmatic® 15A
Spoolmatic® 30A
Direct Connect
Shopmate DX All Serial Numbers Spoolmatic® 15A
Spoolmatic® 30A
Direct Connect
Bobcat 225, 250 All Serial Numbers Spoolmate™ 3545
Spoolmate™ 3035
w/Heavy-Duty Barrel Accessory
SGA-100C #043 857
Spoolmatic® 30A
WC-115A w/Contactor Kit #137546011
Renegade 180 All Serial Numbers Spoolmate™ 100 Series Direct Connect
Trailblazer 275, 302 All Serial Numbers
Spoolmatic® 15A
Spoolmatic® 30A
WC-24 #137549
Spoolmate to Welder Hook-Up Requiring an SGA Spool Gun AdapterĀ
Note: See Spoolmate Hookup Recommendation chart above for power sources requiring SGA spool gun adapter.
  • For Millermatic 135/140, combine Spoolmate 3035 with SGA 100 to weld 14 gauge to 1/8 in aluminum.
  • For Millermatic 175/180, combine Spoolmate 3035 with SGA 100 to weld 14 gauge to 3/16 in aluminum.
  • To weld aluminum with comparable, competitive power sources, the Spoolmate may also be used with one of the SGA units.
  • For Miller Bobcat 225, combine Spoolmate 3035 or 3545 with SGA 100C to weld 14 gauge to 3/16 in aluminum.
  • For Miller Bobcat 250, combine Spoolmate 3545 with SGA 100C to weld 14 gauge to 3/8 in aluminum.
