Choosing What Filler Metal To Use for DIY Welding Projects
No matter the welding process or material, here are six questions to help determine what filler metal to use for your home welding projects.
Having the right wire feeder for the job is more important than many realize. Not only can it help improve weld quality, but it can also lower costs and increase productivity. The right wire feeder ensures that welding operators spend more time welding than they do addressing issues associated with poor wire feeding, which inevitably lead to unwanted downtime.
The first factor to consider when selecting the best wire feeder is how often it will be in use, as the feeder needs to be durable enough to handle the job. It is equally important to factor in the welding gun type and length, as well as the type and size of wire being used.
There are three main categories of wire feeders to choose from: basic, intermediate and advanced.
Basic wire feeders feature one main control to adjust the wire feed speed and are typically the most cost-effective. They do not include meters to indicate how much wire is passing through or to display the exact wire feed speed. They also do not usually feature remote voltage control. To change the voltage, the welding operator must walk to the power source.
Generally, basic wire feeders use a two-roll drive system, which works well with welding guns up to 15 feet long. They also may use a four-roll drive system for welding guns up to 25 feet long. Since they have a less powerful motor, they are best suited for wire that is smaller diameter.
These wire feeders are not used for applications requiring welding to a specific code. More critical welding applications involving pipe, bridge, structural or ASME code work require welding operators to know the exact voltage and wire feed speed they are working with, which means an intermediate or advanced wire feeder would be necessary for the job.
Intermediate wire feeders usually have four-roll drive systems. They are available in single and dual models that hold either one or two spools of wire. These four-roll drive systems grip the wire better and can therefore push larger wire than a simple, two-roll drive system. Some intermediate feeders can even push wire up to 1/8-inch diameter.
Intermediate models can be used with longer guns, up to 25 feet, and typically have more advanced features. Most models include digital meters that allow welding operators to see the precise wire feed speed and voltage. They also include a feature that allows them to control the voltage at the feeder. This voltage control can boost productivity by allowing welding operators to adjust the voltage at the wire feeder rather than at the power source, which could be placed many feet away. In addition, intermediate models typically have a run-in control that allows the wire to feed into the weldment very slowly for smoother arc starts.
Advanced wire feeders offer operators the most control over how they start and stop the wire, and how much speed it has. They typically feature enhanced displays that allow a welding operator to accurately view a variety of settings.
Advanced wire feeders are ideal for the most critical manufacturing jobs, and they have evolved to accommodate multiple materials. Today’s models are capable of switching between programs while welding and are therefore well suited for jobs that use advanced welding processes, like synergic pulse MIG welding. For example, when using this process, an advanced wire feeder regulates a set of parameters to help keep the arc consistent whether the wire feed speeds up or slows down.
Often advanced wire feeders offer dual schedule that allows welding operators to toggle between two different sets of welding parameters. They also typically include gun trigger options that allow the welding operator to select between multiple weld programs. This is ideal for higher-end, high-production cells where it is necessary to weld many different parts and where the welding operator must set up several programs to weld a variety of parts in the same cell.
Some advanced wire feeders have multiple memories and programs for different types of materials. These features allow welding operators to program presets and create programs specific to various wires and materials. For example, a welding operator could have one program for welding with metal-cored wire and another for welding aluminum. The wire feeder can store and recall these presets at different times, as needed. This feature allows welders to run multiple programs and easily make adjustments. It also helps expedite setup time, ultimately boosting productivity.
Advanced wire feeders also tend to have program locks, limits and ranges, which helps keep welders within certain operating windows. In addition, they often have pre-flow, a start parameter, a crater parameter and post-flow. Pre-flow helps ensure operators have good gas coverage and reduces the risk of porosity at the start of the weld. The run-in parameter helps bring the wire in slowly to ensure smooth arc starting. At the end of the weld, the end or crater parameter and post-flow parameter minimize the opportunity for craters or porosity to appear.
Consider these top five factors when setting up and maintaining a wire feeder.
#1: Adjust the drive roll tension correctly.
#2: Properly adjust the spool break tension.
#3: Ensure the gun connections are clean and tight.
#4: Clean the drive rolls with a wire brush and blow the dust out of the drive system periodically with compressed air.
#5: If the wire feeder will not be in use for an extended period of time, remove the spool so the wire doesn’t rust or corrode.
Choosing the right wire feeder for the job makes a big difference in the overall efficiency of a welding operation. By matching the most appropriate wire feeder to the application, welding operators can minimize unnecessary downtime caused by troubleshooting wire feeding problems or addressing quality issues that may require rework.
Take the time up front to determine the needs of the welding operation before selecting a wire feeder. When in doubt, contact a reputable welding equipment manufacturer or welding distributor for assistance.
Posted Jul 12, 2025
Learn about duty cycle in welding, its importance, and how it impacts your workflow. Ensure optimal performance and safety with the right duty cycle.
Regular welder maintenance will keep your machine performing in top shape. Follow these guidelines for common welder maintenance tips.
