Superior Steel Erectors
As one of the top steel erectors in the country, Superior Steel tackles complex engineering, fabrication and erection jobs. Keeping on schedule is critical, which makes productivity and efficiency key for Superior. To help meet customer demand and gain a competitive edge in completing jobs — while also maintaining weld quality to meet code requirements — the company relies on multiple Miller® Big Blue® 800 Duo Pro diesel engine-driven welders to increase productivity with fewer machines, reduce costs and save space on crowded jobsites.
Superior Steel is one of the top steel erectors of its size in the country. Founded in 1978 and based in Knoxville, Tennessee, the award-winning company is uniquely equipped to cater to the precise needs and demands of field superintendents and construction project managers because Superior does it all: engineering, fabrication and erection.
Superior assists customers with design-build projects, and has American Institute of Steel Construction (AISC)-certified fabrication facilities with the capacity to produce more than 18,000 tons of fabricated steel annually. As an AISC-Certified Erector, Superior Steel’s erection division has the equipment to solve most any lifting challenge, whether it’s a 40-ton crane to erect a small project, or three 150-ton cranes to simultaneously lift trusses at a C5 hangar or the Kentucky Expo Center. Among Superior Steel’s 150 employees are experienced, full-time personnel who maintain, transport and set up the company’s cranes, allowing Superior to quickly respond to customer needs.
“We can help customers do whatever they need. We fab our own steel, we erect our own steel and we detail our own steel. We’ve got structural engineers in-house. We’ve got our own trucking,” Superior Steel general superintendent Robert Human says. “We just do it all.”
Meeting demand for large projects
Superior Steel at any one time may be working on 10 or more projects across the country, specializing in large industrial and commercial facilities such as museums, theme parks, stadiums, aircraft hangars, government structures, universities, hospitals and churches.
Keeping on schedule with so many large-scale projects makes productivity and efficiency key for Superior Steel, which employs about 40 welding operators. To help meet customer demand and gain a competitive edge in completing jobs — while also maintaining quality to meet weld code requirements — the company, with help from Holston Gases, recently purchased multiple Miller® Big Blue® 800 Duo Pro diesel engine-driven welders. The upgrade has helped Superior increase productivity with fewer machines, reduce costs and save space on crowded jobsites.
Superior uses the machines for welding and auxiliary power capabilities on structural steel erection jobsites. The engine-driven welders can be used by multiple operators at once — saving space by maximizing equipment capabilities with fewer machines needed on site. The machine provides 800 amps for a single welding operator, 400 amps each for two welding operators, or it can be used as a three or more arc multioperator machine with the addition of inverter-based welders that can be powered off the unit’s auxiliary power. Operators can also use the engine-driven welder to simultaneously power tools such as lights, saws, drills, grinders and fans — with no arc interaction.
“It saves you money on jobsites when you can have more than one welder working off the same machine. You don’t have to keep purchasing welder after welder,” Human says. “It saves a lot on maintenance, filters and oil changes — it’s a big savings.”
One machine for multiple operators
One of the main advantages for Superior is the ability to be more productive with multioperator machines that meet many jobsite needs. It helps the company complete jobs faster, with less equipment on site, and maximizes investment in equipment.
Superior Steel primarily uses the machines with two welding operators simultaneously, for stick and flux-cored welding, ranging from quarter-inch fillet welds on a perimeter angle to full penetration welds up to 2 inches thick. A current job involves welding steel columns that weigh 26,000 pounds each, with flanges 2-inches thick. The power capabilities of the machine — 800 amps for a single weld operator or 400 amps each for two operators, with 20,000 watts of continuous three-phase auxiliary power and 12,000 watts of continuous single-phase power — are important for the types of critical welds Superior completes.
“That’s the good part about these machines — instead of having two machines for two guys to weld, we’ve got one machine running with two guys working off of it,” says Jack Freytag, superintendent and foreman with Superior. “We might also be running it for external power for grinders, screw guns and anything else. It doesn’t cause the arc to fluctuate. You’ve got a more constant flow with this machine.”
The auxiliary power capabilities of the engine-driven welders are important on Superior’s jobsites, which often don’t have available power.
“You’ve got to supply your own power, and these welders come in handy because they’ve got their own auxiliary power that supply power,” Human says.
Space savings and improved safety
It’s also a big space saver for Superior, since reducing the number of machines needed on a jobsite helps minimize the amount of clutter that can make sites overcrowded and potentially unsafe. That’s important, especially on small sites where space is already scarce.
“Construction sites these days are so congested. The sites are getting smaller, and the jobs are getting bigger. You’ve got no room to maneuver everything around,” Freytag says. “One machine with dual operators on it and other functions being used off of it at the same time — it limits the space you have to take up.”
The new machines are also quieter in operation, which contributes to improved jobsite communication and safety.
“The guys need to be able to hear and know what’s going on around them all the time,” Freytag says. “The Big Blue 800 is so much quieter than any of the other machines that we’ve had out here on sites.”
Easy setup and use
Superior workers have also found setup and use to be quick and easy with the new engine-driven welders, which saves time and makes training operators much easier.
“You can set your amperage range to where you need to be the first time. It saves you from going up and down — you could spend several hours going up and down trying to get a machine set to where you want it,” Freytag says. “With the digital readouts on the Big Blue 800, you know where you’re at right then. You set your machine and go. It’s a big savings in time.”
The digital display on the machine shows fuel level, engine hours, coolant temperature, oil pressure, battery volts, and engine rpm, and it also tracks oil change intervals and displays engine diagnostics for easy servicing.
Superior pairs the Big Blue engine-driven welder with Hobart® filler metals on the jobsite, including 7018 series stick electrodes and Excel-Arc™ 71 flux-cored wire. Superior Steel’s welding operators like the reduced spatter they see with the electrodes, which saves time in post-weld cleanup. They also like the productivity gains they see with the flux-cored process and wire, especially on larger jobs that require a lot of welding.
Tackling complex jobs
The multioperator platform and range of capabilities offered by the Big Blue 800 engine-driven welder helps Superior Steel meet a variety of needs on complex jobs and saves space on busy jobsites. That helps the company complete jobs in a timely manner and maximize performance of machines in its fleet.
“It’s cost effective when you’ve got these welders on the jobsite,” Human says. “It saves the company a lot of money.”
It’s important for Superior Steel to meet customer demands, which these days often includes shortened time frames for completing jobs. An engine-driven welder with dual-operator capabilities helps the company get those jobs done on time and remain competitive.
“Having the equipment that will help you to move along and get a better production level, it’s a must,” Freytag says. “It allows us to perform these jobs, bigger jobs and more complex jobs in a timely manner. You can do the job faster and with less equipment. That’s the end game, is to turn these projects over as fast as you can and move on to the next project.”
