Deltaweld® 350
The manufacturing solution for welders of all skill levels, now offering pulse capabilities in an integrated package.
Welding Smarter: How AGCO Unlocked Its Full Potential With the Deltaweld® System
AGCO, a world-renowned manufacturer of tractors and agricultural equipment has been an industry leader for decades. Its customers are hardworking farmers who expect machines that will outlive them, requiring high-quality and durable welds no matter the product.
Across the agricultural industry, stainless steel is increasingly being sourced as a material mandatory in manufactured products due to its durable yet lightweight properties compared with thicker metals. With this shift in material specifications come challenges that many manufacturers haven’t previously faced.
AGCO was planning to launch a new product that would require welding thin stainless steel, which revealed some challenges with welds for the operation. Issues the team faced included warping, bending and inconsistencies in quality — leading to part fit-up issues, decreased structural integrity and lost production time. To compensate, some operators had taken to using their own parameters to tackle the same welds, with some using settings that maximized deposition rates and others using settings that slowed them down.
Weld spatter was a problem too. With sometimes inefficient parameters being set, there was a large amount of unnecessary spatter, leading to more post-weld cleaning. These steps added to the overall production time, causing delays and inefficiencies, and ultimately highlighted the need for a standardized approach to welding to improve consistency, quality and throughput while also solving for stainless-steel-related issues.
Given the customers’ and their own high standards, AGCO recognized that it was going to be critical to dig into and address these challenges — and doing so led to the realization that their existing tools weren’t going to cut it.
Over the past 25 years, AGCO has worked with Miller on custom programming and field testing numerous products. Given the long-standing partnership, they decided to reach out to the Miller team to ask for help.
Jeff Van Muyden, area manager of the AGCO weld department, recalls, “The first thing Miller did was ask a few questions about the problems we were having, and then they sent a team out. They took samples back to their facility and helped us come up with weld settings that would work for us."
Miller’s proposed solutions included implementing standardized weld parameters and investing in a new welder, a Deltaweld® system, which would turn out to be more transformative for their team and their work than AGCO had hoped or expected.
The Deltaweld system, when paired with the Intellx™ Elite feeder, comes equipped with a host of features, including advanced processes like Versa-Pulse™ and a welding software and technology called Insight Centerpoint™. Miller recommended Versa-Pulse for AGCO because it controls the focal area of the heat, providing a tighter arc that helps prevent stainless steel warping and burn-through due to low heat input, creates higher-quality parts and mitigates rework, all while facilitating faster travel speeds. Given the varied level of operator experience, Miller’s recommendation included AGCO continuing to leverage Centerpoint as a user-friendly guide for each weld. Centerpoint shows operators exactly how and where to fit-up the part and in what sequence to weld, along with automatically setting the parameters and showing the operator how to jig up the part, improving weld consistency, ensuring no welds are missed and maximizing operator efficiency.
AGCO took Miller’s suggestions into consideration and into the shop, where they conducted a blind test against the competition and ultimately concluded it was time to make a move to the Deltaweld system.
Since making the switch, AGCO has been able to leverage the Deltaweld system to unlock tremendous upside in its stainless steel work — while also creating growth opportunities for the employees and the operation as whole.
The Deltaweld system also enhances the capabilities of AGCO’s skilled operators, who leverage the Centerpoint weld data monitoring for visual guidance and automated settings that support consistent, high-quality welds. The technology is especially helpful when onboarding new team members or tackling complex parts.
These improvements have been noticed and celebrated by operators and managers alike. AGCO welder Chris Marfechuk emphasized how much time Centerpoint saves him, as well as his teammates. “Seeing it on a picture on a computer screen, we're able to see how the part is supposed to go in the jig, and that helps a lot, especially when we have newer welders come in. We can just say, look at how it's set up in Centerpoint, and they can go from there."
Marfechuk also appreciates how the Deltaweld’s advanced processes minimize cleanup. “I find Versa-Pulse leaves a lot less weld spatter. Welds come out cleaner, which saves me time in the long run, and it just makes it look a lot better."
Deformation is down too, and travel speeds are up, thanks to the minimal heat input that comes with Versa-Pulse, with Van Muyden noting, “It helps us control the heat input. Helps us with a little bit of our travel speed, so we weld a little bit faster on thinner gauge material without running the risk of deformation at the end."
Management is happy that they use Centerpoint to automatically adjust parameters and Versa-Pulse to minimize heat input, with components manufacturing lead Jeffrey Wright saying, “The investment in the Deltaweld was worth it. You get fewer weld defects in parts and reduced setup time thanks to the intuitive interface and automated parameter adjustments. The weld quality meets our high standards and supports the durability our customers expect."
From the initial stages of outreach when the stainless steel problem was identified to the after-purchase support, the AGCO team hasn’t looked back. Miller® has maintained its role as a steadfast partner to the company and been available to assist every step of the way, from troubleshooting to manually updating the Deltaweld® system’s software when firmware upgrades are needed.
The Deltaweld system has proven to be reliable in the demanding environment, and Miller representatives are always ready to lend a hand. According to Van Muyden, “They’re just a phone call away. It's one of the most reliable machines that I've personally seen, and I've been in this business for over 20 years.” The partnership has supported AGCO’s dedication in upholding its industry-leading reputation for producing durable and high-quality equipment.
Posted Sep 21, 2025
Dedicated wire feeders. Easy to use. Legacy meets pulse. The standard in industrial manufacturing.
Dual wire feeder for Deltaweld 350 with new arc control. Intellx feeder, BTB 300A, .035/.045 rolls.
For the Beets and Schnabel crews on Discovery Channel’s “Gold Rush,” mining can be a 24/7 operation — with millions on the line.
Deltaweld® 350 with Intellx™ Elite offers a user-friendly screen, eliminating guesswork and boosting productivity. Discover Miller’s intuitive welding technology.
Learn how the Safran Nacelles Group reduced weld distortion and rework when TIG welding titanium with a switch to the Miller® Dynasty 400 TIG welder.
Structural welding codes in earthquake-prone Seattle are stringent. Apex Steel delivers code-quality welds efficiently with Miller technology.
Boilermakers Local 92 needed to train new members on new welding processes - faster. Advanced welding processes and new technology were key.
Wheeler's fleet optimizations transformed technicians into a resilient service force with improved weld quality, reduced idle time, extended truck life, and safety.
Dobbs Equipment uses the HDI Air Pak to streamline repairs and reduce downtime at a high-output sand mine.
Switching between TIG and stick welding polarity can be a time consuming process. Technology from Miller makes it much simpler for NAES.
Houston fabrication facility Exterran greatly improved production and reduced defect rates with PipeWorx and RMD® welding process.
Learn how Komatsu improved speed and efficiency by adopting SubArc Hercules, enabling the Longview team to cut weld time and stay ahead of demand.
Discover how B&W Trailer Hitches transformed their manufacturing capabilities with Miller® PerformArc™ robotic welding systems. Learn how automation drives quality and efficiency — see what it could do for your operation today.
See how Hartnell College brings real-world welding automation into the classroom to meet evolving manufacturing workforce needs.
Repairs on a mining site are a daily occurrence. The Schnabel crew on "Gold Rush" uses reliable Miller equipment to keep operations running.
Uncover how the Miller® team helped AGCO improve operator efficiency and ease while decreasing defects in their stainless steel welding operations.
Ascendum’s fleet overhaul with Miller EnPak® A60 units cut costs, boosts uptime and empowers technicians to deliver superior service.
Dynamic Manufacturing transformed their welding automation speed and quality using IntelliPath™ technology. See the impact on their operational success.
See how IFH Group used robotic welding automation and offline programming to increase throughput 25 to 30 percent on a family of larger tanks.
Learn how Team Industries created their own in-house welding training to address the shortage of skilled welders in the workforce.
Discover how new welding technology helped this racing organization boost productivity and long-term growth. Learn how they found success.
Take a look inside two different models of welder training at Tulsa Welding School and Blinn College and how they use Miller® welding equipment.
Henderson Products relies on the Deltaweld system and Intellx™ wire feeders with pulsed MIG welding to reduce training time and spatter.
G.G. Schmitt & Sons saves time and money welding anodized aluminum with Miller® Dynasty® 400 TIG welders, cutting hours of rework.
DE-CAL, Inc., relies on Miller equipment and technology to become one of the premier mechanical contractors in its region.
A change to Miller® FILTAIR® fume extraction systems helped decrease weld fume exposure and improve productivity for American Seating employees.
Implementing Miller® FILTAIR® MWX Mobile Fume Extractor helped improve air quality and productivity for Muscle Car Restoration employees.
A welding process change allowed Dixie Mechanical to eliminate back purging and double the number of welds completed every day.
TC Energy switched from TIG and stick welding to wire processes for large-bore pipe on several projects and greatly improved productivity.
Mexia High School welding students enjoy hands-on experience with Miller® equipment and training resources.
Wheeler CAT significantly reduced engine idling, to an average of 1% on a truck with a fully integrated cab heating and cooling system.
