"Gold Rush" Crews Tackle High-Stakes Mining With Miller® Equipment
For the Beets and Schnabel crews on Discovery Channel’s “Gold Rush,” mining can be a 24/7 operation — with millions on the line.
Compact by Design, Tough by Nature: HDI™ Air Pak™ in Action
As a full-service John Deere equipment dealership in the Southeast, Dobbs Equipment is the go-to service partner responsible for keeping its customers’ heavy-duty equipment running smoothly, even in the toughest conditions.
With limited tooling, American Materials Company (AMC), a high-output sand mine, is yet another business that relies on Dobbs to keep its mobile fleet up and running, which includes a lineup of several John Deere front loaders. Active since the late 1970s, AMC produces up to 3,000 tons of sand a day — which is enough to fill 200 school buses — and supplies topsoil, fill, concrete and mason sand for their customers in the Eastern Carolinas. Dobbs’ ability to respond quickly, often same-day or next-day, is essential to ensure plant throughput and keep the mine running at full capacity. Any delay in equipment repair can halt production, disrupt delivery schedules and impact AMC’s ability to meet customer demand within the given timeline.
But with abrasive conditions and constant wear on loaders’ pins and bushings, Dobbs was looking for ways beyond their skilled team of technicians to conquer tight turnaround times. That's where the HDI Air Pak comes in.
Dobbs’ technicians face more than just tough repairs at AMC’s sand mine. When they go to work every day, they are at battle with their environment, one that grinds down both their equipment and productivity. Sand infiltrates every crack and crevice and clogs up greasing systems, making frequent repairs to the John Deere loaders unavoidable. Just clearing a workspace of all the excess sand can take up to 30 minutes, which creates an obstacle for timely repair. That’s why having a consistent, endless air supply is crucial to remove debris from the equipment so repairs can be made. On top of this, service technicians face tooling limitations and constant pressure to minimize their downtime on the jobsite. Every minute lost to equipment failure or inefficient setup puts AMC’s production and customer commitments at risk.
To stay ahead, Dobbs’ technicians need to be responsive and equipped with a solution that is as tough and dependable as they are — built to perform in the harshest conditions and keep operations moving without delay.
Repairs in the mines mean hauling around multiple machines to get the job done: one for welding, another for compressed air and a third for power. The HDI Air Pak significantly simplified Dobbs’ operations. Its hydraulically driven, all-in-one design eliminates the need for separate compressors and welders, saving up to 400 pounds in weight on the work truck and reducing the equipment footprint by 54%. In addition, less gear means more valuable truck space to accommodate other essential tools and parts needed to complete tasks more easily. This results in fewer trips, faster setups and more efficient repairs, even in extreme weather.
Because of the constant sand exposure at the mine, weather resilience is key, and the HDI Air Pak is built for environments just like it. Its integrated and compact design is ideal for extreme environments — heat and cold, as well as remote and rugged environments. Designed with industry-leading technologies and weld quality, its reliability across harsh conditions ensures Dobbs can perform repairs without delay.
What really impressed Dobbs was the all-in-one performance the HDI Air Pak offers. Up to 325 amps of multiprocess welding power — including MIG, TIG, stick and air carbon arc gouging — at a 100% duty cycle, plus 40 or 60 cfm of air for uninterrupted tool use, meant fewer machines and more capability. Add 150 amps for battery charging, 300 amps for crank assist, and a 7,000-watt generator for auxiliary power, and Dobbs’ technicians can handle electrical issues on-site without delay, no extra equipment required.
“Being able to keep the truck running all day without worrying about running out of fuel in a standalone air compressor or generator makes all the difference in the world — endless air supply, constant use — it’s wonderful,” said Justin, a Dobbs service technician. “The HDI Air Pak unit is immediate, it’s consistent, there’s no delay and it performs well under many conditions. Overall, it provides a better end result.”
Simplified operation was another standout. A single digital panel controls all functions, reducing training time and setup complexity — especially helpful for newer techs. And with Auto-Set™ technology, Dobbs can count on consistent weld quality with fewer errors. Features like toolless maintenance and CAN bus connectivity also streamline service and fleet tracking, helping technicians stay efficient and reducing downtime across the board.
When considering safety, modular remote panels help reduce slip and fall risks by eliminating the need to climb into truck beds. This not only protects technicians but also helps maintain productivity by preventing avoidable injuries.
For Dobbs, it’s not just about fixing equipment; it’s about delivering uptime, every time. The efficiency of the HDI Air Pak has proven to be the ideal solution to amplify the Dobbs team’s need to provide AMC with fast, effective delivery and service. The all-in-one design has transformed field operations, equipping their technicians with a reliable machine that performs under the toughest circumstances. As a result, AMC benefits from reduced downtime, improved safety and a streamlined maintenance process that creates a more resilient operation. Together, Dobbs and the HDI Air Pak are helping AMC meet rising customer demand without compromise.
Posted May 5, 2024
Deltaweld® 350 with Intellx™ Elite offers a user-friendly screen, eliminating guesswork and boosting productivity. Discover Miller’s intuitive welding technology.
Learn how the Safran Nacelles Group reduced weld distortion and rework when TIG welding titanium with a switch to the Miller® Dynasty 400 TIG welder.
Structural welding codes in earthquake-prone Seattle are stringent. Apex Steel delivers code-quality welds efficiently with Miller technology.
Boilermakers Local 92 needed to train new members on new welding processes - faster. Advanced welding processes and new technology were key.
Wheeler's fleet optimizations transformed technicians into a resilient service force with improved weld quality, reduced idle time, extended truck life, and safety.
Dobbs Equipment uses the HDI Air Pak to streamline repairs and reduce downtime at a high-output sand mine.
Switching between TIG and stick welding polarity can be a time consuming process. Technology from Miller makes it much simpler for NAES.
Houston fabrication facility Exterran greatly improved production and reduced defect rates with PipeWorx and RMD® welding process.
Learn how Komatsu improved speed and efficiency by adopting SubArc Hercules, enabling the Longview team to cut weld time and stay ahead of demand.
Discover how B&W Trailer Hitches transformed their manufacturing capabilities with Miller® PerformArc™ robotic welding systems. Learn how automation drives quality and efficiency — see what it could do for your operation today.
See how Hartnell College brings real-world welding automation into the classroom to meet evolving manufacturing workforce needs.
Repairs on a mining site are a daily occurrence. The Schnabel crew on "Gold Rush" uses reliable Miller equipment to keep operations running.
Uncover how the Miller team helped AGCO improve operator efficiency and ease while decreasing defects in their stainless steel welding operations.
Ascendum’s fleet overhaul with Miller EnPak® A60 units cut costs, boosts uptime and empowers technicians to deliver superior service.
Dynamic Manufacturing transformed their welding automation speed and quality using IntelliPath™ technology. See the impact on their operational success.
See how IFH Group used robotic welding automation and offline programming to increase throughput 25 to 30 percent on a family of larger tanks.
Learn how Team Industries created their own in-house welding training to address the shortage of skilled welders in the workforce.
Discover how new welding technology helped this racing organization boost productivity and long-term growth. Learn how they found success.
Take a look inside two different models of welder training at Tulsa Welding School and Blinn College and how they use Miller® welding equipment.
Henderson Products relies on the Deltaweld system and Intellx™ wire feeders with pulsed MIG welding to reduce training time and spatter.
G.G. Schmitt & Sons saves time and money welding anodized aluminum with Miller® Dynasty® 400 TIG welders, cutting hours of rework.
DE-CAL, Inc., relies on Miller equipment and technology to become one of the premier mechanical contractors in its region.
A change to Miller® FILTAIR® fume extraction systems helped decrease weld fume exposure and improve productivity for American Seating employees.
Implementing Miller® FILTAIR® MWX Mobile Fume Extractor helped improve air quality and productivity for Muscle Car Restoration employees.
A welding process change allowed Dixie Mechanical to eliminate back purging and double the number of welds completed every day.
TC Energy switched from TIG and stick welding to wire processes for large-bore pipe on several projects and greatly improved productivity.
Mexia High School welding students enjoy hands-on experience with Miller® equipment and training resources.
Wheeler CAT significantly reduced engine idling, to an average of 1% on a truck with a fully integrated cab heating and cooling system.
