8 Plasma Cutting Tips To Improve Results
From setup to technique, some plasma cutting tips and tricks will help you improve plasma cutting results.
Plasma cutting is easy and extremely efficient, but is not without its hazards: electricity, gas, ultraviolet light, etc. This article details a few key safety factors to consider before striking an arc.
Like a hot knife through butter, a plasma arc cutting machine slices through any electricity-conducting metal faster than traditional cutting methods, including saws, snips or oxy-acetylene torches. Although the technology has been available for more than 50 years, the introduction of small, portable (less than 50 lb.) and affordably-priced machines in the mid-1990s produced phenomenal growth in the use of plasma arc cutters. Many artists, farmers/ranchers, sign makers, do-it-yourselfers, repair shops, maintenance facilities and metal fabricators regularly use this technology.
However, because of its newness, many people are not familiar with proper plasma arc cutting safety procedures. Fortunately, basic safety practices are not hard to learn.
The plasma cutting arc blows out hot metal and sparks, especially during the initial piercing of the metal. It also heats the workpiece and cutting torch, all of which can cause fire and burns. To protect your eyes while plasma cutting, wear approved safety glasses with side shield. For increased protection, use a face shield or helmet in conjunction with safety glasses.
To protect your body from flying sparks and hot metal, always wear dry, undamaged, flame-resistant clothing and gloves. Clothing made from tightly woven material - such as leather, wool or heavy denim - works well. Button shirt collars, cuffs and front pockets to prevent them from catching sparks. Do not keep matches or butane lighters in your pockets. Avoid wearing cuffed pants, as the cuffs may catch sparks. High-top leather shoes or boots provide the best foot protection.
The intensely hot and powerful plasma arc can quickly cut though gloves and skin. To prevent injury, do not grip material near the cutting path. The pilot arc can cause burns, too, so keep away from the torch tip when pressing the trigger. When starting the arc, point the torch away from your body and toward the workpiece.
Since heat and sparks can ignite flammable materials, move all flammables at least 35 ft. away from the cutting area or protect them with flame-proof covers. Take extra care to close off small cracks and openings in partitions, as sparks can easily pass through them. Never cut on closed or pressurized containers, such as tanks or drums. Do not cut on containers that may have held combustibles or toxic or reactive materials unless they have been tested and declared safe by a qualified person. When cutting on a ceiling, floor, bulkhead or partition, remember that sparks and metal can ignite combustible materials on the hidden side. In fact, never plasma arc cut near flammable gases, vapors, liquids, dust or in locations where explosions are possible.
Plasma arc cutting torches are typically designed with safety interlock systems that turn off the machine if operators loosen the shield cup or if the tip touches the electrode inside the nozzle. However, plasma arc cutting requires higher voltages than welding to start and maintain the arc - typically 110 to 400 VDC - and touching live electrical parts can cause fatal shocks or severe burns. Poor connections and bare spots on cables increase the possibility of electrical shock. Inspect these items daily and replace, not repair, any worn cables or broken connections.
Because water conducts electricity very well, avoid wet working conditions (even body perspiration can lower the body's resistance to electrical shock). Insulate yourself from work and ground by standing on a dry rubber mat or dry plywood sheet big enough to cover the full area of your contact with the work or ground. Be cautious, as both rubber and wood can ignite. If you can find a dry, non-flammable material to stand on (put between you and ground), use it.
When plasma arc cutting equipment is properly grounded according to the National Electrical Code (NFPA 70) and to OSHA standards, a voltage may safely exist between the electrode and the work, making the cut possible.
Operators must routinely inspect for effective ground connections. Connect the workpiece to a proper earth ground. Connect the frames of all electrically powered machines to a properly grounded disconnect switch, receptacle or other appropriate ground. Always double-check the installation and verify proper grounding. Never use chains, wire ropes, cranes, hoists and elevators as grounding connectors.
Arc rays produce intense visible and invisible (ultraviolet and infrared) light rays that can burn eyes and skin. Proper clothing protects your skin, but your eyes need the additional protection provided by a face shield or safety glasses outfitted with the correct lens shade.
To determine the proper lens shade, check your machine's amperage capabilities and then consult Figure 1 (see ANSI Z49.1 for shade numbers used with plasma cutting above 80 amps).
To protect others from flash and glare, install and maintain approved screens and barriers where appropriate. Warn observers before initiating a plasma arc.
Cutting any metal produces fumes and gases, and breathing them can create health hazards. Keep your head out of the fumes and do not breathe them. (Hint: For a better view of the cutting arc, hold your head to the side of the torch. Don't peer directly over it). Work only in a confined space if it is well ventilated or while wearing an air-supplied respirator and while complying with other ANSI requirements.
When cutting coated metals - such as galvanized steel, lead- or cadmium-plated steel - remove the coating from the cutting area if possible. These coatings, and any metal containing these elements, can give off toxic fumes when cut with a plasma arc (always read the Material Safety Data Sheets (MSDS) for all coatings, metals and consumables used in the process). When cutting coated metals, ventilate the cutting area and use an exhaust hood or suction system - positioned at the arc - to keep the breathing zone safe and clear of fumes. If necessary, wear an air-supplied respirator.
Plasma arc cutting systems use shop air and sometimes compressed gases, typically nitrogen. When using cylinders, securely chain them to a stationary, upright support or cart at all times. When moving or storing a cylinder, fasten the threaded protector cap to the top of the cylinder. This shields the valve system from impact damage.
Immediately remove a faulty regulator from service for repair. Do not attempt to repair a faulty regulator. Instead, send it to the manufacturer's designated repair center where it will be repaired according to the manufacturer's specifications.
Use only recommended ferrules or clamps designed to connect hoses to fittings. Never use ordinary wire or other substitutes. Always suspend the hose off the ground to keep it from being run over, stepped on or otherwise damaged. Avoid long runs or coil excess hose to prevent kinks and tangles. Examine all hose regularly for leaks, wear and loose connections. Replace leaky or worn hoses, or repair them by cutting out damaged area and properly splicing in a new section. Never splice hoses with tape; it cannot ensure a safe seal.
Plasma arc cutting can cut metal safely, but you must follow proper procedures to avoid accidents. Because this article does not cover all the safety issues that may exist, always refer to the operator's manual and ANSI Z49.1, "Safety in Welding, Cutting and Allied Processes," for a thorough explanation.
Do you have questions about plasma pattern cutting? Get some tips and learn about equipment selection, pattern design and setup.
