Deltaweld® 350, 500 and 600
Deliver production-grade performance that standardizes quality and reduces variability.
The pressure to keep production moving never stops. You can't afford to slow down, but inconsistent welding leads to rework, delays and quality issues.
Miller helps you get more from your team with solutions that keep you ahead of the game. Our equipment is easy to learn, set up and use, meaning fewer mistakes and more work out the door.
With fewer welders available, Kurt was being asked to do more with less, a problem every manufacturing manager is facing. The challenge becomes even greater when quality and output rely on experience rather than process. Miller helped his crew get more done.
“One of the biggest challenges in the last five years has been mostly getting staff, getting skilled welders.”
3 Phaze Fab
For Jeff’s crew, excessive heat input was getting in the way of consistent weld quality across materials. Differences in weld quality across operators, shifts or stations slow production down. Miller helped his team standardize performance.
“The investment in the Deltaweld was worth it. You get fewer weld defects in parts and reduced setup time thanks to the intuitive interface and automated parameter adjustments.”
AGCO
IFH Group needed a way to automate unique orders without slowing production, a frequent challenge managers deal with. Setup changes, manual adjustments and rework pull skilled operators away from productive work. Miller solutions helped simplify setup and increase IFH Group's throughput by 25-40%.
“We would take multiple days to write a program. With Intellipath and DTPS offline programming, the process can all be done in a matter of hours.”
IFH Group
Limited floor space doesn't have to limit productivity. Optimizing workspaces with Miller solutions can improve flow, increase flexibility and make it easier to adapt as production demands change.
No matter the challenge, Miller solutions are designed to help you scale, get more from your crew and get ahead. Call us today to find out how we can help you deliver.
