Respiratory Protection
When should respiratory protection be incorporated to manage weld fume levels?
According to OSHA, respiratory protection should be implemented in cases where engineering controls are not feasible, while they are being implemented, or when engineering controls alone do not reduce hazard levels below Permissible Exposure Limits (PEL).
How do I choose between a PAPR, half mask, and SAR?
When deciding between a Powered Air-Purifying Respirator (PAPR), half mask respirator, and supplied air respirator (SAR), consider the specific requirements and benefits of each option.
The half mask is versatile and can be comfortably worn under your preferred welding helmet, but it does require annual and daily fit checks, and users must be clean-shaven for a proper seal.
On the other hand, the PAPR eliminates the need for fit checks or clean-shaven requirements, making it a convenient option you can use wherever you are. However, PAPRs' general configuration is bulkier than that of a half-mask respirator.
It is important to note that SARs provide effective cooling and do not require a fit check or clean-shaven skin, though their portability is limited by hose length.
Respirators also vary in terms of Assigned Protection Factors (APF), where half masks provide a protection factor of 10 while PAPRs and SARs provide a protection factor of 25 or more. Analyze your work environment and needs to determine which option best meets your safety and comfort requirements.
What is the difference between air-purifying and atmosphere-supplying respirators?
OSHA has identified two major types of respirators: Air-purifying and atmosphere-supplying.
Air-purifying respirators have filters or cartridges and remove particulates from the air by filtering them prior to reaching the welding operator.
Atmosphere-supplying respirators provide clean air from an uncontaminated source.
Proper fitting is key with some types of respirators, such as half masks, so be mindful that fit tests may be required to ensure a proper seal.
What is an Assigned Protection Factor (APF)?
An Assigned Protection Factor (APF) rating denotes the workplace level of respiratory protection that a respirator or class of respirators is expected to provide to employees when the employer implements a continuing, effective respiratory protection program.
Learn more about APFs for OSHA's revised respiratory protection standard.
What is OSHA's Respiratory Protection Standard?
OSHA's Small Entity Compliance Guide for the Respiratory Protection Standard helps employers determine when respirators are needed and how to select, use, and maintain them properly. The guide covers key program requirements, including hazard assessments, respirator selection, medical evaluations, fit testing, employee training, and ongoing program management to help ensure workers are protected from airborne hazards.
Read the Small Entity Compliance Guide for the Respiratory Protection Standard or review 29 CFR 1910.134(c).
What are the documentation and inspection rules for respirators?
OSHA requires an employer to develop and implement a Written Respiratory Protection Program with required worksite-specific procedures and elements for both mandatory and voluntary respirator use. For employees voluntarily using respirators, employers must provide those users with a copy of Appendix D to OSHA 1910.134.
Respirator inspection is an important step that can help ensure the respirator is in proper working order. Employees should be trained on proper inspection procedures before any kind of respirator is used. This information can be found in a respirator's user instructions.
Employee training should also cover topics including proper selection of respirators; the consequences of improper fit, usage or maintenance; proper maintenance and storage procedures; and how to use respirators in emergency situations.
How should welding respirators be stored and maintained?
When using a respirator, proper storage, cleaning and replacement of the units is important. The written respiratory program requires a filter change schedule. Respirator filters must be replaced, as they cannot be cleaned, unlike other fume extraction products.
