Flux-Cored Welding: The Basics for Mild Steel
What is flux-cored (FCAW) welding?
Flux-cored arc welding (FCAW) is a welding process which is excellent for welders of all skill levels, especially those who weld outside or on dirty material. It is similar to MIG welding but comes with the advantage of not requiring shielding gas.
Using flux-cored welding vs. MIG
Flux-cored welding comes in two main forms, self-shielded and gas-shielded, and each behaves differently when compared to MIG welding. While both processes use a wire electrode fed through a gun, flux-cored welding relies on a flux-filled wire to help protect the weld, making it more tolerant of wind, contaminants and outdoor conditions than traditional MIG welding.
Self‑shielded flux‑cored welding
Self-shielded flux-cored welding is a wire welding process in which a continuous hollow wire electrode is fed through the welding gun into the weld joint. Unlike MIG welding, it doesn’t require an external shielding gas, such as carbon dioxide or argon, to protect the weld pool from contamination. Instead, a flux compound contained within the wire reacts with the welding arc to form a gas that protects the weld pool.
Gas‑shielded flux‑cored welding
Gas-shielded flux-cored welding, on the other hand, does require a shielding gas. It’s often used in heavy-duty industrial fabrication and manufacturing and is not typically recommended for beginner and hobbyist applications.
How flux‑cored compares to MIG
Both forms of flux-cored welding create a layer of slag that sits on top of the finished weld and must be chipped off. As a result, they often are less visually refined than MIG welds. For these reasons, many operators choose MIG for indoor applications where appearance and cleanup are priorities.
Key advantage for welding outdoors
One of the main benefits of self-shielded flux-cored welding is its reliability in outdoor conditions. Because the flux within the electrode creates its own shielding gas, this process avoids the common issues faced by MIG welding — namely, the risk of wind blowing the external shielding gas and compromising the weld quality. Additionally, the flux-cored process is more forgiving when working with base metal that is somewhat rusty, dirty or otherwise contaminated.
Flux-Cored Welding Basics: Tips for Flux-Cored Welding
Preparing metal for welding
As mentioned earlier, flux-cored welding is more tolerant of surface contamination than MIG welding. However, you should always clean the surface of the base metals as thoroughly as possible to ensure that a rusty or scaly surface does not contaminate the final weld. A metal brush or grinder works well for cleaning the base metals. Also, be sure to clean the portion of the base metal where you plan to attach the ground clamp. Poor contact with the ground clamp will create resistance in the welding circuit and could result in poor weld quality.
For material over 1/4 inch, it’s usually a good idea to bevel the edges of the base materials to ensure complete fusion of the two parts. This is especially true for butt joints.
img9605jpg
Although flux-cored welding is more forgiving of dirty metal than MIG welding, it’s still a good idea to clean off as much surface contamination as possible prior to welding.
Setting up for flux-cored welding
Successful welding starts before you strike an arc. To ensure your equipment is in shape to begin welding:
Check your cables. Check your welding equipment to make sure all of the cable connections are tight and free of fraying or other damage.
Select electrode polarity. Flux-cored welding requires DC electrode negative, or straight, polarity. You'll usually find the polarity connections on the inside of the machine near the drive rolls.
Use the correct drive rolls. Because flux-cored wire is softer than solid wire, knurled drive rolls provide a good “bite” on the wire without compressing and deforming it — which could happen if using standard drive rolls.
Check wire tension. Too much or too little tension on either the drive rolls or the wire spool hub can lead to poor wire feeding performance. Adjust according to your owner’s manual.
Inspect consumables. Remove excess spatter from contact tips, replace worn contact tips and liners, and discard the wire if it appears rusty.
Choosing wire for flux-cored welding
For general purpose mild steel welding applications, a flux-cored wire with the designation E71T-11 can be used in any position, is available in a wide range of sizes and provides excellent welding characteristics for both thin and thicker material. Hobart® Filler Metals offers such a wire under the name Fabshield® 21B (E71T-11).
When selecting wire diameter, consider the following:
.030-inch wire is a good all-around choice. It works well across a variety of metal thicknesses and is suitable for general-purpose welding tasks.
.035-inch wire is better suited for thicker materials or applications that require higher heat input. It provides deeper penetration and stronger welds.
.045-inch wire is ideal for heavy-duty welding, but only if your welder can support the larger diameter. It’s commonly used in industrial settings where maximum strength is needed.
Setting your wire stickout
Stickout refers to the length of unmelted electrode extending from the tip of the contact tube, excluding the arc length. Generally, flux-cored welding requires a stickout of around 3/4 inch, which is about twice the recommended stickout for MIG welding.
img9657jpg
A 3/4-inch stickout is recommended for flux-cored welding.
Determining voltage and amperage needs
How much voltage and amperage a weld requires depends on metal thickness, joint configuration, welding position and wire diameter. Reference charts are available on your power source to help set the correct voltage and wire feed speed based on the wire diameter and material thickness. Consider these tools to be rough guides from which you can fine-tune your final parameters based on a few test welds.
img9644jpg
Your power source contains reference charts for setting the correct electrical and wire feed parameters.
How to flux-core weld
Understanding positioning and angles is important to every welding process as these factors directly contribute to overall weld quality.
FCAW gun technique: push or drag?
With flux-cored welding, you should always use a drag (pull) technique. This involves pointing the tip of the welding gun back at the weld pool and dragging it away from the completed weld. An easy rule of thumb for remembering which technique to use is “If there’s slag, you drag.”
Use a standard travel angle
Travel angle is the angle relative to the gun in a perpendicular position within the plane of the weld joint. Normal welding conditions in all positions call for a travel angle of 5 to 15 degrees. Travel angles beyond 20 to 25 degrees can lead to more spatter, less penetration and general arc instability.
Correct work angles are relative to the welding position
The work angle is the gun position relative to the plane of the welding joint, and it varies with each welding position and joint configuration (see below).
Welding in a Flat Position
img9774jpg
For a butt weld (a 180-degree joint), hold the gun at a 90-degree work angle — the same angle from each workpiece. Direct the filler metal straight into the joint with a 5- to 15-degree travel angle. A small side-to-side motion with the gun can help fill a large gap or when making multiple passes. Pausing slightly at the sides of a weave bead can help avoid an undercut.
img9829jpg
For a T-joint (a 90-degree joint; the type of weld on this joint is called a fillet weld), position the gun at a 45-degree angle, or equal distance from each piece. When making multiple weld passes, adjust the work angles slightly toward one side and then the other to avoid uneven weld beads and undercuts.
img9761jpg
For a lap joint (also a fillet weld), angle the gun between 60 and 70 degrees to direct more heat into the bottom piece of metal. The thicker the metal being welded, the greater the angle needed to ensure proper penetration and weld quality.
img9806jpg
Horizontal position
Because of gravity, the gun work angle must be lowered slightly, by 0 to 15 degrees, so that the welding gun points upward toward the top piece of metal. Without changing the work angle, the filler metal may sag or roll over on the bottom side of the weld joint.
The travel angle generally remains the same as for a weld joint in the flat position.
When making multi-pass welds on thick metal or to bridge a slight gap where fit-up is poor, a slight weave may be used to fill a weld joint. A slight hesitation at the top toe of the weld helps prevent undercut and ensure proper tie-in of the weld to the base metal. Voltage and amperage settings for flux-cored welding in the horizontal position are usually the same or slightly less than settings for welding in the flat position.
Angle the welding gun slightly upward for horizontal welds to accommodate for gravity.
img9831jpg
Vertical positions
Vertical welding, both up and down, can be difficult. This makes pre-weld setup very important for producing high-quality welds. Since you are fighting gravity, consider reducing the voltage and amperage 10 to 15 percent from the settings for the same weld in the flat position.
Vertical down technique: When welding vertical down, begin at the top of a joint and weld down, weaving slightly side to side. For thin metal where burn-through is a concern, keep the electrode wire on the leading edge of the weld puddle. This technique helps when welding thin metals because the arc penetrates less due to the faster travel speed.
Vertical up technique: This is like vertical down but can provide better penetration on thicker materials (typically 1/4 inch or more). The travel angle of the gun is a 5 to 15 degree drop from the perpendicular position. Use a slight weaving motion.
Remember to weld upward for increased penetration and downward for thinner metals.
img9851jpg
Overhead position
An overhead weld is the most difficult weld to make, and it should be avoided if possible. If you cannot avoid welding in the overhead position, try using the smallest wire possible, lowering your welding parameters by 15 to 20 percent, keeping your weaving to a minimum and maintaining a fast travel speed. Even following these tips, it still may be difficult to achieve a sound overhead weld.
Successful flux-cored welding
Creating a successful flux-cored weld (or any arc weld for that matter) requires more than just memorizing the correct parameters and gun travel guidelines. Only through practice and learning to read the weld pool will you be able to consistently achieve sound flux-cored welds. With practice, you’ll begin to learn to troubleshoot and self-correct any shortcomings in your welds.
So, don’t get frustrated if your welds don’t look perfect on your first try. Just keep practicing, and before you know it, you’ll be scouring your garage for new things to repair or fabricate.
MIG Welding
How to MIG
Posted Jan 11, 2026
