Shortage of Experienced Welders
Keep your shop productive despite a shrinking pool of skilled welders. Help your crew get more done, no matter their skill level, with Miller. Copilot™ Builder™ brings automation to your team, making it easy for welders of all skill levels to deliver code-quality welds with consistency. FabCO® Triple 7 flux-cored wire works hand in hand with Copilot Builder and advanced processes like Accu-Pulse™, producing a clean, low-spatter arc that cuts down on post-weld cleanup and rework.
Little Rock XMT 650 ArcReach REZ7994
Shop Safety
In busy welding shops, safety and efficiency go hand in hand. Leverage Miller's tools and technology to keep welders safe and focused. XMT® 400 ArcReach® allows you to adjust weld parameters right at the arc. Less walking, fewer trips over cables and more time welding. FabCOR® Element™ XP filler metal has low fume emissions and produces smooth, low-spatter welds that reduce airborne particles and risk of injury. And Miller® helmets provide all-day comfort and proper ventilation, plus enhanced visibility due to ClearLight™ 4x auto-darkening lenses, which reduce the risk of accidents in tight spaces.
Dealing With Limited Space
Every jobsite is different — some are more confined than others. To assist your operation when mobility is limited, we’ve engineered solutions to save space and reduce the need to walk across confined work areas. The Trailblazer® 330 and Big Blue® 400 Pro engine-driven welders gives welders ultimate freedom and control thanks to Wireless Interface Control. This grants welders full access to machine settings and engine functions from a handheld wireless device. XMT® racks organize your operation’s power into a single source by consolidating individual units spread across the site.
Venture 150S Application_REZ3366
Difficulty Transporting
Lugging heavy machines across mud, gravel and uneven surfaces is no joke and can risk potential injury and equipment damage. Plus, big machines can take up valuable truck and trailer space and increase setup and teardown time. At 27 pounds, the battery powered Venture™ 150 T and Venture™ 150 S are designed to be compact, lightweight and easy to transport between jobsites. By eliminating the need to carry heavy leads and extra equipment, the convenient design also cuts down on setup and pack-up time, with time savings of up to 250 hours annually.
Trailblazer 330
Limited Power
Clean and consistent power is not a guarantee out in the field, but that doesn’t mean your operation needs to suffer. We offer a range of solutions to maintain efficiency for your crew, like the Trailblazer® 330 engine-driven welder that offers weld and auxiliary power on demand. XMT® multiprocess welders are equipped with Auto-Line™ technology, which ensures consistent arc performance by automatically adjusting for fluctuating input voltages. Auto-Line equipped machines are also more compatible with Hobart® Quantum Arc™ 6 solid wire, which delivers clean metal transfer and requires less power to maintain a stable arc.
Venture 150 S - Portland 04
No Power
Sometimes there’s no power when you’re out in the field — and we’ve got a solution for that too. The lightweight, swappable battery packs on the Venture™ 150 S and Venture™ 150 T allow you to weld basically anywhere without the need for extra equipment or complex setup. The rechargeable 400 Wh batteries are specifically engineered for welding and packed with plenty of power to get the job done quickly and efficiently.
Trailblazer 330 Application_117A4945
Skilled Labor Shortage
Experienced welders can be hard to find, but with the right welding solutions you can extend the capabilities of your less experienced crew to boost productivity and maintain quality across every job. The Trailblazer® 330 engine-driven welder features a user-friendly digital interface, providing easy access to advanced settings for more control and exceptional weld quality. With Auto-Set™, operators of all skill levels can quickly and accurately set weld parameters. Wireless Interface Control allows users to manage the machine from anywhere on the jobsite. Additionally, we make FabCO Triple 7 flux-cored filler metal, which delivers smoother welds and requires less technique mastery. All so you can accomplish more, no matter who's in your crew.
xmt-400-arcreach-eastern-shipyard_rez5294_other-slider-images_720x410
Field Safety
Safety in the field is our number one priority. That’s why we design solutions to minimize the risk of falls, fumes and burns. The XMT 400 ArcReach allows you to adjust weld parameters right at the arc, minimizing time spent walking through cluttered jobsites. FabCOR Element XP is a low fume emission filler metal that reduces the risk of injury by producing smooth, low-spatter welds. And Miller helmets with ClearLight™ 4x auto-darkening lenses provide enhanced visibility and proper ventilation, which helps reduce accidents.
Structural Steel Welding 1
Time-Consuming Parameter Changes
When you’re on the job, every unnecessary moment spent on parameter changes is money wasted. So we deliver streamlined solutions to help minimize setup and keep your operation running efficiently. The XMT 650 ArcReach and the ArcReach SuitCase® HD both come standard with ArcReach technology, which allows you to adjust weld parameters right at the wire feeder. That means no more lengthy walks back and forth to your machine just to get set up. And the IronPro™ FCAW gun further simplifies setup with Auto-Set™, which helps welders of all skill levels quickly and easily optimize weld parameters.
Still have questions?
Our team of professionals is here to help!
