ArcReach FAQ
[PDF]
Low Conductivity Coolant
Insulation Products
Heating
Recorder Software and Tutorials: Sure Controls™ Inc. Support
Recorder Software (Note: Select Eurotherm 6000 Series Software Download)
Important! Delete previous software prior to installation
Use the Settings screen on your PC’s ArcReach® Heater Data Application Program to input heating values and other information.
Learn the basics of programming your ArcReach® Heater and how to troubleshoot common issues.
See how to clean and care for ArcReach® Heaters and heating tools so they maintain efficient operation and consistent heating.
Learn how to properly connect either one or two heating tools to your ArcReach® Heater.
See how to properly set up your ArcReach® Heater, connect cables, place insulation and more.
Learn how to properly care for your ArcReach® Heater and tools. Topics covered include pre-use checklist, cleaning and more.
See how to enter a heating profile on your ArcReach® Heater, either manually or by using preloaded data from a USB flash drive.
Learn how to choose the right heating tool, properly apply it to your workpiece and set it up with your ArcReach® Heater.
Watch this short video to learn how to manage the control thermocouples on your ArcReach® Heater.
See when to use an air-cooled quick wrap and how to properly position it for the best results with your ArcReach Heater.
Learn the meaning of ArcReach Heater Extension Cable Box indicator lights — and how to react when “fault” light illuminates.
Identify ArcReach® Heater tool damage/wear requiring repair. Learn what to repair yourself and what needs professional assistance.
Learn about your ArcReach® Heater’s Heating Parameters screen — and how to make adjustments to ensure the best heating results.
This short video shows you how to save and extract temperature data with your ArcReach® Heater.
Learn how to set up a heating data file on your PC and save it to a USB flash drive for use on your ArcReach® Heater.
Watch this short video to see how to quickly and easily troubleshoot fault codes on your ArcReach® Heater.
Use your ArcReach® Heater for manual or programmed hydrogen bakeout after the preheat cycle is completed.
Learn when to use insulation your ArcReach® Heater, what kind and how much to use, and the right way to apply it.
See how to properly attach the insulation fault detection magnet to the workpiece and to your ArcReach® Heater.
See how to properly place thermocouple (TC) sensors on the workpiece and connect them to the ArcReach Heater.
Learn how to use the ArcReach® Heater Data application to chart the heating data recorded by your ArcReach Heater.
Effectively use your ArcReach® Heater by following guidelines on induction tools, cables, thermocouples, insulation and more.
Properly set up/position air-cooled cables and connect them to your ArcReach Heater for optimal results on small-diameter pipes.
Learn more about how to program and diagnose the ProHeat induction heating system.
Learn more about the ProHeat induction heating air cooled system.
Learn about the ProHeat induction heating liquid cooled system.
Learn more about the ProHeat induction heating power source.
