From poor feeding capability to questions about durability, we’re debunking common misconceptions about suitcase wire feeders.
A few persistent myths about suitcase wire feeders may be keeping contractors from switching to more productive wire welding processes — and from reaping the benefits.
Let’s debunk the most common misconceptions about wire feeders and set the record straight about feeder quality and performance.
FACT: Some manufacturers design wire feeders for simplified setup, allowing operators to change the wire and drive roll in a matter of minutes. And wire welding processes are generally easy to learn and use compared to traditional processes like stick and TIG. This makes them an efficient option when training new welders. Advanced wire processes such as pulsed MIG and modified short-circuit MIG make it easier for operators to control the weld puddle. They are also more forgiving to variations in part fit-up or changes in contact tip-to-work distance. This can help less experienced operators complete quality welds more efficiently.
While switching to wire processes on the jobsite may require some training, productivity gains can be significant. One contractor making the switch from TIG to modified short-circuit MIG on the root pass and from stick to pulsed MIG on the fill and cap passes found the training necessary to vary — with a welder’s experience using a MIG gun and with open root welds as the biggest factors impacting training time. The arc is programmed to be more forgiving and easier to use, which contributes to ease of use and faster training.
FACT: When operators experience wire feeding issues like bird-nesting or burnback, the wire feeder often gets the blame. In reality, these problems are typically caused by a different culprit somewhere downstream. For example, cranking the drive roll tension too tight can deform the wire and result in wire feeding problems. Or dirty, damaged or improperly installed liners or contact tips can also cause issues.
Miller® SuitCase® wire feeders deliver smooth and consistent wire feeding, thanks to new technology that helps reduce drag on the wire. Inlet guides (which direct the wire coming off the spool and into the gun) that use an offset goalpost-style design help minimize drag and wear on the wire. Also, suitcase feeders that use a scaled wire pressure knob help prevent feedability issues that result from overtightening the drive rolls.
FACT: The design and construction of suitcase wire feeders have come a long way in recent years. Today’s wire feeders provide durability and performance on even the most demanding jobsites. For example, Miller SuitCase wire feeders are encased in polypropylene with built-in slide rails. Operators can drag the feeder into position by the handle and still protect it from wear.
FACT: Some wire feeders also provide the capability for advanced wire processes such as pulsed MIG and Regulated Metal Deposition (RMD®), a modified short-circuit MIG process. These processes can offer substantial productivity improvements compared to stick and TIG while maintaining high weld quality. The RMD process is excellent at bridging the gap in root passes, and operators can create a thicker root pass. This often allows them to omit the hot pass when switching from a TIG to RMD root.
FACT: Changing weld parameters on the jobsite doesn’t have to be difficult. Miller wire feeders with ArcReach® technology allow welders to make adjustments right at the feeder. This eliminates the need to walk back to the power source to make changes. When paired with XMT® 350 FieldPro™ power sources, these wire feeders also include Cable Length Compensation (CLC™) technology, which adjusts voltage based on weld lead length, ensuring that the voltage a welder sets is the voltage he or she gets — even hundreds of feet away from the power source.
The technology in suitcase wire feeders has improved significantly since their introduction. Today’s wire feeders offer simplified setup, smooth and predictable wire feeding, and durability for demanding jobsites. A versatile wire feeder delivers the capabilities for a range of wire processes in the field — saving you time.
Learn more about how your operation can improve productivity with wire processes and suitcase wire feeders.
