Common Food Grade Welding Mistakes and How to Avoid Them
Do your manufacturing operation’s goals include improving productivity, reducing weld defects or controlling costs?
A weld data monitoring system can provide the insight to drive improvements and achieve the results you want. Your operation can get more done, produce higher-quality welds and control costs that may be hindering growth.
With data monitoring, operations can:
Get answers about when an operation should consider a data monitoring solution, the benefits of these systems, and tips for how to implement a data monitoring system to achieve optimal results.
Data monitoring can be used for robotic and semi-automatic welding systems to identify and solve welding-related problems. Systems track key metrics within individual weld cells and across the entire welding operation.
These systems offer several key benefits, including:
Collecting data manually is time-consuming, adding delays to any corrective actions that are identified as important. It can also be prone to errors. Manually collected weld data also needs to be compiled, interpreted and analyzed before decisions can be made. Investing in a data monitoring system can eliminate these issues and offer a faster, more accurate solution for collecting data and turning it into actionable information.
As with any technology investment, the decision to purchase a data monitoring solution should be made with careful consideration. It’s important to first consider the goals of the operation and what key performance indicators you want to measure.
Applications for basic monitoring
Applications for more advanced monitoring
See how weld data monitoring fits into a digitized operation.
When it’s time to choose a solution, there are several options available, ranging from basic to more advanced.
Weld Data In One Place With Insight Welding Intelligence
Insight Core is a cloud-based weld data management solution. It is designed to monitor and report welding productivity with a goal of improving arc-on time and filler metal deposition rates. Think of Insight Core as a manager's tool for passive monitoring of a welding operation.
Insight Core allows you to:
Measure welding productivity. Operations can see each welder’s arc-on time, which can be used to set baselines, plan improvements and measure progress toward goals.
View easy-to-understand reports. Data that’s hard to analyze can hide important facts about your welding operation. Insight Core dashboards allow operations to identify important trends and develop reports with data that can be analyzed for action. Use the data to evaluate comparisons between operators, weld cells, and physical plant locations. Core can report these trends by day, week, month, shift and more.
Identify welding costs. Not knowing true welding costs keeps operations from realizing where costs can be lowered. Insight Core helps you identify the costs in the welding operation, so you can make improvements that reduce expenses.
Install and use easily. Insight Core only requires an internet connection to gather data. Secure data is viewable from anywhere on any web-connected device.
Multiple levels of customizable dashboards provide an at-a-glance view of performance.
The system provides vital facts about the machines in operation, including:
In addition to helping identify and track production goals as part of continuous improvement initiatives, the dashboards can collectively help companies assess their costs. They provide information to determine true welding costs, identify areas where costs could be reduced and track the outcome of cost-reduction efforts.
With powerful reporting tools that allow customized views of each of these dashboards, it’s easier for leadership to analyze the company’s productivity and goal metrics in a way that is the most intuitive to them.
This solution provides welding operations with a real-time solution that guides welders through weld sequences, reducing training time and missed welds.
Insight Centerpoint is integrated into Miller Continuum™ and Deltaweld® power systems. It is an on-premises application that can integrate with enterprise IIoT solutions and scale to meet and operations needs.
Insight Centerpoint allows you to:
Reduce training time. A complex weld sequence can require a lot of training time. Insight Centerpoint helps reduce training time by guiding welders through a weld sequence in real time. It also prompts operators to perform pre- and post-weld activities required to build the part.
Ensure quality welds. Out-of-parameter welds create rework if they aren’t captured early in the weld cycle. Insight Centerpoint can monitor every parameter of every weld, which helps operations contain weld defects early and provides more control of the weld operation.
Reduce costs. Missed or defective welds that aren’t detected early in the process are more costly to fix later. Insight Centerpoint alerts welders if a weld is missed or if a weld is outside of acceptable parameters, allowing it to be corrected more efficiently and cost-effectively.
Remotely configure content. A user of an engineering station hosting Centerpoint can create and validate part configuration remotely and off line prior to plant floor deployment.
Watch this video to learn more about the benefits of Insight Centerpoint weld data monitoring.
Reduce Weld Defects and Ensure Consistent Quality
Some operations only want basic productivity data while some need advanced process control. In choosing the right solution, it's important to think about installation requirements, the key performance indicators you want to measure and the level of control and feedback desired.
To gain the optimal results when using these systems, consider some important do's and don'ts for implementing them. It’s important to manage your expectations since data monitoring is not a silver bullet for every challenge in your welding operation.
Insight Core tips:
Insight Centerpoint tips:
Many manufacturing operations can benefit from investing in a data monitoring solution. These technologies can deliver results through reduced costs and rework, increased throughput and faster welder training.
