Explore the Controls
Try the Syncrowave® 212 interface.
907911
Syncrowave Series Interface Simulator
The Syncrowave 212 makes TIG welding more approachable than ever. With a little ambition and some grit, you can pick up a new skill and start taking on projects that require TIG in no time.
Syncrowave 212 AC/DC TIG Welder
1. Turn power on. 2. Select Process: AC TIG, DC TIG, DC Stick or MIG Spool Gun. 3. Set amperage or voltage based on material thickness. Then weld! It’s as easy as 1, 2, 3.
The standard 14-pin connector lets you choose your control for a customized experience, whether it’s a foot control, fingertip control, or wireless foot control.
