High-Vacuum Systems
Industrial high-vacuum system designed specifically for welding. Ideal for fabrication and manufacturing environments where versatility is needed, this system provides fume capture at the source using multiple fume guns and attachments simultaneously.
new
Filtair 215
Filtair 215
Unique fabrication and manufacturing settings require unique fume capture solutions. The FILTAIR 215 provides high-vacuum fume extraction for up to four operators at a time. The high cfm allows for long hose reach, so it's an effective solution even when placed far away from the welding activity. The FILTAIR 215 is a set-it-and-forget-it-type unit, optimized so you can realize efficiencies in per-operator cost while improving performance.
New
Works with Fume Guns
FILTAIR 215 works with any fume gun, including the Bernard® Clean Air E™ fume extraction MIG gun. Capture up to 95% of fumes at the source with this fume extraction gun, designed for use in environments from heavy industrial to truck and trailer manufacturing to fabrication.
Compare FILTAIR® 215 and FILTAIR® 130
| Filtair® 215 | Filtair® 130 | |
| Ideal Applications | Heavy Manufacturing Fabrication Automation/Robotic | Manufacturing Light Fabrication Small Shops MRO |
| Weight | 390 lb. | 46 lb. |
| Nominal Airflow | 215 cfm | 132 cfm |
| Filter Type | Self-Cleaning MERV 16 | Manual Cleaning MERV 15 |
| Number of Operators | 2-4 | 1 |
| Input Power | 208-230V / 1Ph / 60Hz 460V / 3Ph / 60Hz 575V / 3ph / 60Hz | 115V / 1Ph / 60Hz |
| Horsepower | 5.5 hp | 1.7 hp |
