How to Reduce Welding Troubleshooting With Suitcase Wire Feeder Technology
Technology can make life easier on the jobsite, but which option best meets your needs? Learn more about how to compare welding technology.
Your engine drive is a workhorse that lets you complete a wide range of jobs in the field — from multiprocess welding and gouging to powering tools and lights. But the need to frequently adjust weld settings or switch between welding processes can be a hassle when you have to walk back to the welder/generator each time or if you have an unreliable accessory.
When operators can easily adjust weld settings right where they’re working by using a remote pendant or wire feeder that provides communication back to the power source, it can save significant time and money, especially on large jobsites where there are many tasks to be completed.
So how do you know which options can best meet your needs and help you complete jobs efficiently? Keep these factors in mind when choosing an engine drive and accessories for the jobsite.
Having an engine drive and stick/TIG remote accessory that aren’t binding easily and reliably is a hassle that wastes time and keeps you from getting work done — and it reduces the effectiveness of the accessory. Poor connectivity between the engine drive and the accessory makes the accessory essentially unusable. You need reliable equipment that works when you need it to get the job done.
A Miller® ArcReach® stick/TIG remote binds quickly and consistently to Miller engine drives with ArcReach technology, so you start work immediately.
If a remote pendant or wire feeder doesn’t provide the ability to select and change your welding processes at the point of the work — forcing you to walk back to the power source to make those adjustments — you don’t have the ability to maximize the convenience of the technology.
Some systems will automatically choose the correct process based on how the machine is set up. Auto-Process Select™ technology from Miller detects electrode polarity as well as the ArcReach accessory being used and will set the welding power source to the correct process.
Look for engine drive accessories that let you toggle between direct current electrode positive (DCEP) processes such as xx10, xx18 and gouging on the remote pendant. When configured in direct current electrode negative (DCEN), the remote will automatically select the TIG process. Likewise, the ArcReach feeder detects the polarity configuration to automatically select either the DCEP MIG/FCAW-G or DCEN FCAW-S process.
Not all technologies for the jobsite were created equal, and most are limited in their ability to fine-tune the arc remotely.
When engine drive accessories lack this capability, welders might make do with less than optimal arc control settings rather than walk back to the power source to make adjustments. It can seem like a time saver, but it can result in weld quality issues or even rework.
Arc control through an ArcReach accessory — available on all ArcReach Trailblazer® and Big Blue® welder/generators — provides precise arc control (also known as dig), allowing you to fine-tune the arc. If you encounter a tight root fit-up or need to weld out of position, turning up the arc control on the stick/TIG remote will match the application by providing a stiff arc. Then during fill and cap passes or when welding in the flat position, the arc control can be lowered — without making the trip back to the power source — for minimal spatter and desirable wetting at the toes to create an excellent-quality finished weld.
Having arc control allows you to match your welding preferences and quickly dial in the proper parameters using the remote — to optimize weld quality and maximize productivity. This delivers more flexibility and greater control.
On busy jobsites, sometimes an operator or a helper makes adjustments on the interface of the wrong engine drive thinking it’s their own machine — unintentionally causing problems by changing a different operator’s settings.
To avoid this hassle, look for an engine drive and accessory that will lock out any changes on the machine interface once the two have been paired. ArcReach engine drives and accessories have front panel lock out. When adjustments can only be made on the accessory after pairing, it helps prevent the hassles and potential rework of accidental changes.
Point-of-use control capabilities are available with a range of machines and accessories, but how can you be sure you’re getting the model you want? You don’t want limited engine-drive capabilities due to confusion about compatibility or which machines include the technology.
Many engine drives from Miller come standard with ArcReach technology and can be paired with numerous ArcReach stick/TIG remote and wire feeder accessories that deliver point-of-use control of weld settings and process selection. This helps ensure you’re getting the industry-leading capabilities you need with the engine drive you choose.
See the full range of ArcReach® capability options.
You tackle a wide variety of jobs in the field, so you need a versatile engine drive that delivers consistent performance and the capabilities to weld, gouge, use air tools, deliver generator power and complete other tasks. Reliable communication between the engine drive and accessories — and the ability to control process changes and adjust the arc from the point of work — will help you get work done efficiently.
