Welding Aluminum vs. Steel – Tips to Improve Your Results
Learn the key differences between welding aluminum vs. carbon steel so you can confidently weld aluminum.
Learn the fundamentals that make aluminum welding more consistent. This cluster covers cleaning and preparation, base metal behavior, filler setup, heat control and the differences between aluminum and steel. Use these resources to understand why aluminum requires a different approach, how to avoid common defects and how to choose the right process before starting a MIG or TIG aluminum weld.
