Longer-Reach Cobots Are Expanding What's Possible in Heavy Fabrication
Bobbi Jo Matheny
Product Manager
Automation has often felt out of reach for heavy fabrication manufacturing. Traditional robot cells are powerful, but they require rigid setups, dedicated tooling and significant upfront investment. In high-mix or project-based environments, that rigidity can limit flexibility. Conversely, collaborative welding robots have historically been used for lighter-duty work, such as smaller parts, shorter welds and compact environments.
Improvements in arm reach and automation usability are pushing those limits, making it easier to bring automation to larger, more complex weldments. Solutions like the Miller® Copilot™ Builder™ featuring the FANUC CRX-30 70-inch arm provide a more practical path to automating work that was once considered too big, too variable or too difficult to justify.
Expanding weld access in heavy fabrication
One of the biggest barriers to automation in heavy fabrication has always been access. Larger weldments often require frequent repositioning or complex fixturing just to reach all the necessary welds. Longer-reach collaborative robots change that equation and offer a more adaptable alternative. With extended reach, manufacturers can:
  • Access more welds on large assemblies, like base plates, structural components and long seams
  • Reduce the need to reposition parts mid-process
  • Minimize investment in complex, dedicated tooling
  • Automate portions of large assemblies without committing to a fixed configuration
  • Adjust setups as workloads or part designs change
  • Scale automation over time instead of making a single large investment
The result is a simpler, more flexible setup that allows shops to automate more without redesigning their entire workflow. This flexibility is especially valuable for shops serving multiple markets or bidding project-to-project work.
Scaling productivity without increasing welding automation complexity
An extended reach naturally helps reach the entire weld area on a larger part, but it can also improve overall throughput. With the ability to access more of a work area, operators can:
  • Stage multiple parts or zones around the system
  • Increase arc-on time without constant intervention
  • Step back to handle other tasks while the system continues welding
For many shops, this means longer run times, fewer interruptions and better utilization of both labor and equipment. As collaborative automation has matured, ease of use has become just as important as overall reach. The Miller Copilot Builder platform is designed with this in mind.
The Copilot user experience is built specifically for welders, prioritizing clarity, guided workflows and hands-on programming that aligns with how welders already think and work. Instead of relying on complex coding or dedicated robotics specialists, operators can:
  • Experience improved waypoint accuracy with AccuGuide™ positioning control
  • Quickly adjust programs as needed
  • Stay directly involved in the welding process
Even with the addition of a longer-reach FANUC arm, the programming experience remains consistent. For current Copilot users, transitioning to a longer-reach system requires minimal retraining, allowing teams to scale capability without increasing complexity.
FANUC builds on what shops already know and trust
Many manufacturers already use FANUC robots for applications like material handling or part manipulation. Integrating a long-reach FANUC arm on a welding cobot is a natural extension of FANUC’s widely recognized name in industrial automation. Pairing the Copilot Builder platform and straightforward programming software with a FANUC arm delivers:
  • A system that aligns with equipment many operations already trust
  • Familiar maintenance expectations for operations teams
  • A more seamless entry point for facilities already using FANUC technology
As a fully integrated system, it’s designed to ensure that communication between the arm, power source and software works seamlessly out of the box.
Guiding your automation journey from start to scale
The biggest challenge for manufacturers that are new to automation is knowing where to start. Miller’s approach centers on partnership and hands-on support throughout the process. Getting started with Miller typically involves the following steps:
  • On-site evaluation: A Miller automation specialist reviews your current workflow, parts and production goals.
  • Application matching: Identifying where a system like the Copilot Builder with FANUC can deliver the most value.
  • Application validation: Testing parts in a Miller applications lab, where welding engineers program and weld real components.
  • Proof of performance: Providing welded samples, video and reports to validate operational feasibility before investing.
This process helps reduce risk, build internal confidence and ensure the selected solution is aligned with real production conditions.
Expanding what automation can do in heavy fabrication
While longer-reach cobots literally expand the physical reach of the automation, they also expand what heavy fabrication manufacturers see as possible. With improved flexibility, easier programming and a collaborative approach to implementation, automation becomes:
  • More approachable for teams without deep robotics expertise
  • More adaptable to changing production demands
  • More aligned with how modern fabrication shops actually operate
Solutions like the Copilot Builder with FANUC CRX-30 help bridge the gap between capability and usability, giving manufacturers a tool that not only addresses today’s labor and productivity challenges but supports long-term growth.
As more shops look to automate larger, more complex weldments, longer-reach collaborative systems are providing a clear next step that balances reach, flexibility and ease of use in a single solution.
Welding Automation and Robotics
Posted Aug 12, 2026
