    Jan 2012
    6
    Default Syncrowave 210 will not boot up
    I just bought a Miller Syncrowave 210 welder two weeks ago
    today I welded for some time
    took a break for lunch
    turned it back on
    display board displays Syncrowave 210
    no menu options come up
    any suggestions
    Bob
    8,172
    Turn your breaker off then back to on . Your missing a phase
    Jan 2012
    6
    Default It is a single phase 110/220 machine
    226
    Are you running it 220 ? Just flip the breaker off and back on like cruzier said.
    Jan 2012
    6
    I was using the machine on 110 Volts
    8,172
    OH, yeah its one of those odd units. It's likely stuck on 220, best bring it in, as its having voltage switch issues. The unit senses input voltage, and isn't sensing to drop to 120
