Results 1 to 7 of 7
Thread: help please
    Default help please
    I just got a welder at a garage sale for 45 dollars I was trying to find an operators manual or anything about it on the web but I cant find anything... serial number A76020465, stock 1353-0217, Airco, 230 amp msm stinger lll ac welding machine
    more pics
    8,281
    Don't really need an operators manual, just plug it into a 230 plug, get yourself some AC stick rods, some weld cable. and weld away. The turn style on top sets your heat, and the high low options are for rod size. It's not a Miller, by the way.
    PA
    369
    Here is an old data sheet I had for Stinger II.
    Hope it helps.
    Nov 2003
    3,623
    Smile Century..??.....
    What you may be looking for are some guidelines to stick welding..
    the machine itself is a pretty generic moveable core AC stick welder..
    hope this booklet helps.. it is a free PDF download..
    http://www.millerwelds.com/pdf/guidelines_smaw.pdf
    and more resources..
    http://www.millerwelds.com/resources...-skills/stick/
    (My first guess is that it was one of the ones made by "CENTURY" and oem'd under several brand names and colors over the years...
    or maybe by Mid-States Manufacturing??)
    My Blue Stuff:
    Dynasty 350DX Tigrunner
    Houston, TX
    900
    Are you sure it's not a Miller? I had a 1970 vintage Airco that was Miller.
    ETA, I see the difference now. Mine was pre-Stinger II which IIRC was till made by Miller.
    At any rate, it should be a good machine.
    Apr 2010
    304
    That might be made by Mid-States. I believe AIRCO eventually bought the company, probably for the Dip-Pak MIG welders. It does not look Miller style.
    Miller stuff:
    Dialarc 250 (1974)
    Syncrowave 250 (1992)
    Spot welder (Dayton badged)
