Results 1 to 2 of 2
    Aug 2014
    Default Swapping an xt40 torch for an ICE27 on 375 x-treme
    Hi folks, anyone ever replaced an ICE 27T torch with an XT40 on the miller 375 xtreme? My 27T bit the dust and I have a new xt40 (without the quick disconnect), but the electrical connections and gas fitting looks different.Thanks!
    8,209
    well, I'd be replacing the torch with the one ment for it. Your going to have air pressure problems since the XT 40 was ment for the 625 and 700. Don't frick around mixing and matching. Besides, if its the torch head thats shot, get a replacement torch head, If its a cut cable, merely fix or replace it. Miller makes it super simple
