When welding occurs where the power source is in a dedicated location, the best choice is a bench-top-style or boom-mounted style of wire feeder. These give the greatest flexibility regarding wire type, spool size, the number of drive rolls and a wide array of advanced control options.
Basic Bench-top Feeder
A basic bench-top wire feeder, such as Miller’s 22A and 24A, features a single wire reel assembly, two (22A) or four (24A) gear-driven drive rolls, trigger hold, burnback and run-in speed control and options for spot welding and presetting the voltage and wire feed speed prior to staring the arc.
When welding occurs where the power source is in a dedicated location, the best choice is a bench-top-style or boom-mounted style of wire feeder. |
Here are brief explanations of these basic functions:
• Gear-driven drive rolls. An arrangement where one drive roll is directly powered by the motor and power is transferred to the second drive roll through gears. This can provide more positive feeding performance than a single driven roll with a second “idler” roll because both rolls drive the wire forward.
• Burnback and motor ramp control for better starting and stopping performance (time not adjustable).
• Trigger hold reduces operator fatigue by allowing the operator to make long welds without having to continuously hold the trigger.
• Pre-flow/Post-flow (optional) extends consumable life and reduces weld contamination and porosity by initiating shielding gas flow prior to arc start and continuing gas flow once the weld is complete. Depending on the application—pre-flow /post-flow may be necessary for good arc starts and to prevent cracking – the amount of time needed will vary. A basic feeder can adjust gas flow from 0 to 5 seconds.
• Run-in speed control (optional) can help solve wire popping and stumbling at arc initiation. When starting at low voltages (say 17 volts—it really depends on wire diameter), starts can be much harsher without run-in speed control. This feature sets the run-in speed as a percentage of wire feed speed while welding. The slower speed gives the wire a fraction of a second longer to pre-heat, which in turn helps establish the arc.
• Spot time control (optional) limits arc-on time from .25 to 5 seconds after the trigger is depressed to assist with making spot or plug welds.
• Remote voltage control (optional) This lets the operator easily adjust parameters when the power source is located remotely, such as suspended on a catwalk or racked against a far wall.
• Digital display (optional) to view welding parameters.
• Presettable (optional) wire feed speed and voltage prior to striking an arc to better ensure quality.
There is somewhat of a misperception that two drive roll feeders do not work well in high-duty cycle, day-in/day-out applications. That is not true when the feeder is matched for the application.
Though a basic feeder can run a broad range of wire diameters (say .023 to 5/64 in.), this doesn’t mean that it should be used for larger diameters wires in high duty cycle applications. The simple fact is that a two drive roll feeder does not grip the wire as positively and remove helix (cast, or the “coil memory” from being wound on a spool) as well as a four drive roll feeder. Wire diameters .045 in. and larger (and in some cases .035-in. wires) may experience feeding problems such as slipping and subsequent arc stumbling. If this is the case, it’s time to upgrade.
Bells and Whistles, Greater Control
In addition to the superior feeding performance of four drive rolls, reasons to upgrade include meeting tighter specifications, ensuring consistency between operators, reducing re-work costs and controlling parameters throughout the entire weld sequence. Where basic feeders use more analog/electro-mechanical controls, an advanced industrial feeder like Miller’s 75 Series typically uses more digital/solid-state controls.
Where a basic two drive roll feeder offers options to improve performance, a digital feeder with four drive rolls includes these features as standard offerings, then goes on to offer even more benefits. These include:
• Rotatable wire drive assembly to remove bend from the gun cable. This reduces the gun liner restriction to improve feeding and lengthen the life of the gun liner and cable. “Toolless” assemblies rotate without the need for an Allen wrench, which encourages users to put them in a strain-free position.
• Dual wire reels increase efficiency in applications that require two different wires. Each side can feature a 60-lbs. spool capacity, independent controls and separate meters. This allows an operator to switch instantly between guns and eliminates the changeover delays that occur with single wire feeders. Examples of dual feeder applications could be a solid steel wire and a flux cored wire or an all-position wire and a flat/horizontal wire.
• Boom-mounted feeders rotate 360 degrees and move 60 degrees up and down to create a work area up to 32 ft. in diameter. They can eliminate the need to move the feeder when working on large weldments and help with difficult-to-reach areas. This saves time and money and improves operator comfort by reducing perceived gun weight. Boom-mounted systems also remove unwanted cable clutter from the floor, resulting in cleaner, safer work cells and less service repair for welding cables.
Boom-mounted feeders remove cable clutter from the floor, resulting in cleaner safer work cells and less service repair for welding cables. |
• Automatic run-in control that sets run in wire feed speed at 50 percent of the weld speed.
• Plug and play upgrades that enable shifting from a “standard” digital feeder to a “deluxe” model with the programming features noted below. The ability to upgrade means feeder capabilities can expand as needs change and that hardware investments do not become obsolete.
• Programmable memory enables storing customized weld programs. This reduces set-up time when switching between different weldments and wires and simplifies operator training. This can be especially valuable given the shortage of skilled welding operators. This programability allows ideal parameters to preset for varying weldments. Operator instructions can be as simple as: “Weld joint A with program 1, then weld joint B with program 2.”
• Sequence control provides complete control of the welding parameters: pre-flow, run-in, welding time, crater, burnback and post-flow. On advanced feeders, run-in and crater control allow setting separate voltage and wire feed values and their duration. Run-in control improves arc starting on difficult to start wires such as stainless steel, aluminum or other types of large diameter wires. Crater control steps down the wire feed speed at the end of the weld. This fills in craters that otherwise tend to occur at the end of a weld when the edges of the weld pool cool faster than the center.
• Weld process control provides the ability to set and lock welding parameters to within a set range (± 0 to 10 volts, ± 0 to 150 inches per minute of wire feed speed). This ensures that operators consistently weld within specifications, yet still offer them limited freedom to tailor values to suit their personal techniques. The auxiliary menus for weld process control are protected by a three-digit software code (no dip switches).
• Dual scheduling allows the operator to switch between two welding parameters while welding. This benefits when operators shift between metal thickness or welding positions (e.g., running hotter in the flat position and slightly cooler vertical up). Related to dual scheduling is trigger select, which allows switching weld programs when not welding or in between welds (e.g., changing on the fly like is not possible).
Quality Control
Frazier Industrial, a leading manufacturer of structural steel storage racks for warehousing operations, uses the 70 Series wire feeder to maintain tolerances tighter than AWS standards throughout its 11 North American facilities.
“We run the same welding parameters in every single one of our plants to ensure uniform quality and consistency, no matt
er where the component is made,” says Aaron Evans, quality assurance manager for Frazier. “Our procedures are such that we need to control both the width and the penetration of the bead so that we get good tie-in on both plates involved with the weld. The reason we use the Miller wire feeders is because they help us control part of that process.” The advanced control capabilities allowed Frazier to experience a return on investment of less than three months.
Another convert to the 70 Series is Yellow Jacket Mfg., Inc., a muffler fabricator for agricultural and construction equipment, trucks, all-terrain vehicles and performance and racing vehicles. Yellow Jacket needed to guarantee adhering to specifications to secure its relationship with a large customer but didn’t want to spend money on equipment that contained unnecessary features. The 70 Series provides a happy medium because it costs one-third less than a feeder with pulsed MIG capabilities yet provides the benefits of programmable control.
Frazier Industrial, a leading manufacturer of structural steel storage racks for warehousing operations, uses the 70 Series wire feeder to maintain tolerances tighter than AWS standards throughout its 11 North American facilities. |
It’s a good idea to discuss specific needs with your local distributor. They can direct you toward specific models that include the functions and abilities you’ll need now and in the future. If you’re experiencing poor feeding performance, increased rejection rates or face the need to control welding parameters, this may be the right time to look into upgrading your feeder—and your productivity and profitability.
