A breakthrough demonstration revealed a process that met Komatsu’s needs
With a long-standing relationship with Miller and Hobart and confidence in their process expertise, Komatsu began evaluating metal‑cored wire as a way to improve deposition rates and reduce arc‑on time without sacrificing quality. The wire showed promise, offering faster travel speeds and cleaner welds than the solid wire they were used to. That’s when the Miller and Hobart team introduced an unexpected alternative.
Within that same controlled testing environment, the team was introduced to the SubArc Hercules™ high‑deposition subarc process — an integrated system that combines a suite of components designed to work as one high‑performance solution:
- Hobart® SubCOR™ wire
- SubArc Hercules™ torch
- SubArc power source (Compatible with all SubArc equipment – SubArc DC 650 Digital – SubArc DC 1000 Digital – SubArc AC/DC Digital – Legacy 14-pin SubArc equipment)
- XMT® 450 SubArc Hercules™
- SubArc Hercules™ preheat switch
The demonstration immediately stood out. Engineers watched wire‑feed speed ramp up significantly while amperage held steady, bead appearance remained consistent, and the arc was stable and predictable. The system ran in standard subarc (SAW) mode by default. Flipping the switch to SubArc Hercules engaged the wire‑preheat circuit and Hercules process, unlocking high‑deposition welding without any change to the setup.
“There's always a concern when you're changing something, especially if it's something that you've been doing for a long time. The thing that I love most about Hercules is that it's very user-friendly. It's a matter of flipping a switch.” — Riley
The team saw potential for a dramatic improvement in throughput, especially on large, high‑volume welds in Longview’s heavy‑fabrication environment.
