DIY Welding Project: Multimatic® 220 AC/DC Organizer | MillerWelds
Share
Andy shows how to transform your Multimatic® 220 AC/DC with custom trays and shelves.
Download Project Plan
SKILL LEVEL: Beginner
TIME COMMITMENT: 4–6 hours
Here's what you'll need to get started.
Tools and Materials
Mild Steel Icon 20 ga. mild steel 24" x 48"
bending pliers icon Bending or seaming pliers
handshear icon Electric hand shear
Aviation Tin Pliers Icon Aviation or tin snips
Hammer Icon Hammer and dead blow
vise icon Vise
C Clamps Icon C-clamps
ruler icon Rulers for marking
magnetic square icon Magnetic squares
STEP BY STEP
step 1
STEP 1:
Using an electric shear, cut your 20-gauge mild steel to 5 3/8 inches by 24 inches. Straighten with a dead blow hammer if needed.
step 2
STEP 2:
Measure 3 inches, 17 inches and 3 inches from the edges, then cut off the remaining 1-inch piece. This will form the back and two sides. Straighten cut edges with a dead blow hammer if needed.
step 3
STEP 3:
Bend the two 3-inch sides to 90 degrees using a vise and a dead blow hammer.
step 4
STEP 4:
Remove the extra MVP plug and mount from inside the machine.
step 5
STEP 5:
Test fit the bent piece to ensure it clears everything.
step 6
STEP 6:
For 12 trays and a top shelf, you need 5 dividers measuring 3 1/16 inches by 4 7/8 inches.
step 7
STEP 7:
Use an electric or straight-line shear to cut out the dividers.
step 8
STEP 8:
Smooth the cut edges if needed.
step 9
STEP 9:
Measure the back side length between the two sides. Divide by 6 to get the spacing for your dividers. Mark the locations.
step 10
STEP 10:
Secure dividers with a magnetic square and tack weld them in place.
step 11
STEP 11:
Decide on the layout of your shelves. Options include a flat top, angled middle and bottom shelf.
step 12
STEP 12:
Cut the top shelf to 16 15/16 inches by 3 1/8 inches.
step 13
STEP 13:
Trim the two long side corners for radius clearance.
step 14
STEP 14:
Clamp to a table and hammer/form a 1/2-inch, 90-degree bend.
step 14
STEP 15:
Trim the top corners of the dividers at a 45-degree angle, flush with the top tray.
step 15
STEP 16:
Spot tack the top tray to the back side and dividers.
step 17
STEP 17:
Verify the spacing measurements between the dividers.
step 18
STEP 18:
Cut and bend the trays. Middle trays: 2 13/16 inches by 3 3/8 inches with a 5/8-inch, 60-degree bend. Bottom trays: 2 13/16 inches by 3 5/8 inches with a 1 3/4-inch, 60-degree bend.
step 19
STEP 19:
Determine the vertical spacing for the trays. Middle tray: 1 1/4 inches from the top edge of the divider to the top of the 60-degree lip. Bottom tray: 1 3/8 inches from the bottom edge of the dividers.
step 20
STEP 20:
Before welding trays, make a clearance cut on the middle divider to clear the door latch. Use a paper template for accuracy.
step 21
STEP 21:
Spot tack the trays in place, starting with the middle tray, then the bottom one. Adjust the Multimatic® 220 AC/DC to 18-gauge and fine-tune the wire speed to 185.
step 22
STEP 22:
Paint your organizer black to match the interior of your Multimatic® 220 AC/DC or a color of your choice.
step 23
STEP 23:
Load the organizer with all your consumables.
Andy Weyenberg
Andy Weyenberg HeadshotAndy Weyenberg began welding at his father’s business a few years before joining the Army. After going to school for Electro-Mechanical, he started working for Miller Electric Mfg. LLC as a technical service rep and training instructor. Andy has built and raced stock cars since he was a teenager — and now builds high-performance street vehicles while also managing the Miller motorsports program.
Published:
