I wanted to build a custom cart to organize my welding setup for my new Millermatic 211 PRO. The goal was to create a solution that could hold my MIG welder, two gas bottles and provide a convenient tray for storing essential supplies. This way, switching between processes would be seamless without the need to swap bottles and everything I need would be within easy reach.
I started by placing two gas cylinders side by side, then stacking my welders in front of them to check clearances. This let me determine how much space I needed to move each item on and off the cart. With those dimensions worked out, I sketched out the shelves for each welder, the platform for the bottles, and the storage tray. I also decided on the size of the wheels, and before long the cart’s design was taking shape.
One of my favorite projects from last year was a three-legged stool I built with a graduated hole pattern in each leg, and I wanted this welding cart to have a similar look. Getting the right curvature for the shelf braces and the optimum hole spacing took a little trial and error, so I used a simple CAD program to refine the details. You could do the same with a manual layout.
