Generator power is critical for me to get everything done on the jobsite. I need generator power to run grinders and other jobsite tools. Sometimes I stick weld with 7018 rods but I don’t usually need to make changes to settings or parameters. I like the option of having a portable machine to put on my truck, UTV or running gear to move it where it needs to be. What's my best solution?
The Bobcat 225 with Remote Start/Stop provides 9,500 watts of continuous, clean and reliable generator power to run the tools and lights that are critical to your job. If you need slightly more output to run larger stick electrodes, the Bobcat 260 with Remote Start/Stop offers the same generator capabilities for powering tools with more welding power. With a compact design, Bobcat welder/generators can be easily moved around the jobsite by truck, UTV or running gear. Remote Start/Stop lets you turn the machine on and off remotely, so you can take control and reduce noise and operating costs.
