Multiprocess welders make it easy to tackle a variety of jobs in the shop or field without switching power sources – saving you time and money.
The Maxstar 280 Series has now expanded beyond the industry leading TIG and Stick performance by the additional CV output which allows for MIG capability - making this multiprocess line the perfect solution for ship building, construction, mechanical contractors and MRO.
Every year, outdated welding equipment can cost you thousands of dollars and hundreds of hours of productive time. Step up to Miller XMT 350 FieldPro systems with ArcReach® technology — and improve your bottom line!
Outdated equipment threatens your productivity, profitability and safety. XMT® 350 FieldPro™ with Polarity Reversing Systems have industry leading technology with no need to manually swap polarity or cables/hoses between processes. The 'Quick-Select' technology automatically selects the welding process, the correct polarity, cable outputs and welding parameters. Optimized Stick and TIG arc performance is specifically designed for open root pipe welding while reducing training time and increasing quality.
Portability and excellent arc performance make the XMT family the most popular in the industry. With many models to choose from the XMT family has the right solution for your business.
The Dynasty 300 Series has now expanded beyond the industry leading TIG and Stick performance by the additional CV output which allows for MIG capability - making this multiprocess line the perfect solution for ship building, construction, mechanical contractors, educational and more.
XMT 650 ArcReach Systems is ideal for structural steel fabrication, general construction, and shipbuilding.
Developed for harsh environmental conditions and output requirements that range from power-intensive to precise.
Designed exclusively for pipe fabrication shops
DC TIG, MIG, flux-cored, and stick welder featuring Auto-Set™ Elite. 120V or 240V input power.
AC/DC TIG, MIG, flux-cored, and stick welder featuring QuickTech™. 120V or 240V input power.
DC TIG, MIG, flux-cored, and stick welder featuring Auto-Set™ Elite. 240V input power.
DC TIG, MIG, Pulsed MIG, flux-cored, and stick welder featuring Auto-Set™ Elite. 208-575 V input power.
