PipeWorx 400 Welding System 230/460 V | MillerWelds
PipeWorx 400 Welding System Package 230/460V
951000094
Designed exclusively for pipe fabrication shops
Compare
951000094
PipeWorx 400 Welding System Package 575V
951000095
230-460V
907382
575V
907384
What's Included
  • PipeWorx 400 Power Source, 230/460V
  • PipeWorx Dual Feeder with drive rolls (300366) Learn More
  • Two 15 ft (4.6 m) PipeWorx 300A MIG Guns (195400) Learn More
  • Side-mount Cable Hangers
  • Cable Kit with 25ft. (7.6m) Work Sense Lead (300367)
Simple Process Setup
  • Clearly labeled controls in easy-to-understand welder terminology.
  • Requires just a few basic steps to set up a new weld process, resulting in less training time and minimizing errors from incorrect setups.
  • The front panel was designed by welders for welders. Only backlit controls are adjustable to eliminate confusion.
  • Memory feature stores four programs for each selection: Stick, DC TIG, and MIG (left and right side of feeder). Beneficial when using multiple procedures, multiple process parameters or multiple welders and eliminates the need to remember parameters.
Quick Process Changeover
  • No need to manually switch polarity or cables and hoses between processes. Simply push a process selection button to choose a welding process. PipeWorx 'Quick-Select' technology automatically selects the welding process, the correct polarity, cable outputs and welding parameter.
  • Quick process changeover eliminates set-up time for switching cables and gas hoses. Also, reduces the risk of weld reworks due to incorrect cable connection.
Multiprocess Machine
  • Weld processes are optimized to deliver superior arc performance and stability specifically for root pass, fill and cap pipe welding.
  • Includes conventional Stick, DC TIG (Lift-ARC™ or HF Start), Flux-Cored and MIG welding processes.
  • Also features the advanced RMD® and Pulsed MIG processes that deliver superior quality welds, increase productivity, and reduce rework and training.
  Learn More
Streamlined System
  • Wind Tunnel Technology™ and Fan-On-Demand™ provide system protection in the dusty shop environment.
  • Innovative cable and gun storage manages clutter for a cleaner, organized weld-cell area. Cables remain connected to the power source and do not need to be switched for the different welding processes.
  • All system components have been selected to meet the needs of a pipe fabrication shop.
Not Included
  • Power Cord
  • Filler Metals
  • Your local welding distributor can provide shielding gas, additional welding wire and a full product offering
  • Shielding gas (for welding with solid wire (GMAW)
Processes
Regulated Metal Deposition (RMD)
Title PipeWorx 400 Welding System Package 230/460V
Industries Interests Shipbuilding
Pipeline
Construction and Fabrication
Amperage 40 A - 400 A
Weldable Metals Specialty Metals
Stainless Steel
Steel
Input Voltage 220/230/240 V
460/480 V
Rated Carbon Diameter 5/16 in (7.9 mm)
Input Phase 3-Phase
Input Hz 50/60 Hz
Max Open Circuit Voltage 90 VDC
Weld Output CC/CV
Applications Fabrication
Industrial Welding
Pressure Vessel
Process Pipe
Refineries and Power Plants
Welding Education and Training
Accessories
Resources
Articles
Operator welds on stainless steel pipe in a shop
A welder completes a pass on carbon steel pipe
Hidden Costs Icon
Videos
