Multimatic® Multiprocess Welders | Miller Welds | MillerWelds
Machines Built for Doers
The Miller® Multimatic® family is as dedicated to hard work as you are. Whether your crew is welding, fixing or fabricating, these MIG, TIG and stick welding machines match your work ethic. With versatile functionality, durability and seamless switch control, these aren’t just tools. They’re your partners in do.
View All Multimatic® Products
multimatic product family
Watch the Multimatic® Seamlessly Switch Processes
Multimatic® 215 PRO
Do It All. Do It Right.
This enhanced multiprocess welder gives you the flexibility to fuel your multi-hustle. With a streamlined interface and more ease-of-use features, you can get set up faster and weld longer to tackle any project on your bench. And it’s backed by legendary Miller reliability to help you do it all, even better.
Product Details
Multimatic® 215 PRO product image
Predefined weld settings to increase ease of use and ensure that the job is done right for operators of all skill levels.
Illustration of Multimatic® 215 PRO interface with Auto-Set.
Illustration of set-up display
MIG Gun illustration
llustration of dinse connections at the front of the Multimatic® 215 PRO
Illustration highlighting usb port for software updates.
Key Features and Benefits
multiprocess icon
Multiprocess
Quickly and seamlessly switch from MIG to TIG to stick.
auto set icon
Auto-Set™
Makes it easy to use on multiple materials and processes with the ability to fine-tune your settings.
enhanced portability icon
Enhanced portability
Each machine is lighter and more compact to make it easier to move with you.
MULTI-TOOLS FOR YOUR MULTI-HUSTLE
Meet All the Members of the Family
Compare All Multimatic® Products
Multimatic®
Capabilities
Multimatic® 215 PRO Multimatic® 220 AC/DC Multimatic® 235 Multimatic® 255
WELDING PROCESS
MIG/Flux-Cored Compatible with Multimatic 215 PRO Compatible with Multimatic 220 AC/DC Compatible with Multimatic 235 Compatible with Multimatic 255
Pulsed MIG Not Compatible with Multimatic 215 PRO Not Compatible with Multimatic 220 AC/DC Not Compatible with Multimatic 235 Compatible with Multimatic 255
DC Stick Compatible with Multimatic 215 PRO Compatible with Multimatic 220 AC/DC Compatible with Multimatic 235 Compatible with Multimatic 255
DC TIG Compatible with Multimatic 215 PRO Compatible with Multimatic 220 AC/DC Compatible with Multimatic 235 Compatible with Multimatic 255
AC TIG Not Compatible with Multimatic 215 PRO Compatible with Multimatic 220 AC/DC Not Compatible with Multimatic 235 Not Compatible with Multimatic 255
DC Pulsed TIG Not Compatible with Multimatic 215 PRO Compatible with Multimatic 220 AC/DC Compatible with Multimatic 235 Compatible with Multimatic 255
WELDING CAPACITY
Mild and stainless steel 24 ga. min
3/8 in. max
24 ga. min
3/8 in. max
24 ga. min
3/8 in. max
24 ga. min
1/2 in. max
Aluminum 18 ga. min
3/8 in. max
24 ga. min
3/8 in. max
18 ga. min
3/8 in. max
18 ga. min
1/2 in. max
POWER
Input Power (V) 120/240 120/240 240 or
(204-276)
208-575
Amperage Range (A) 20-230 20-230 20-235 5-350
PRICING
Testimonials
The Multimatic® 255, if you work in a weld cell, is also extremely portable and multi-functional, as it can be removed from its welding cart and either set on the workbench or set under the workbench to gain you more space.
— Andy Weyenberg, Miller Welders
My favorite feature is the Auto-Set™. The time that it takes to switch between different materials and thickness of material, and how close the Auto-Set is… [it’s] a phenomenal feature on this machine.
— Mike King,
Head Maintenance Mechanic with Combined Locks Public Works
