High Pressure Regulators
Heavy-Duty High-Pressure Regulators
820 Series high-pressure regulators are for use on cylinders with a wide variety of non-corrosive inert gases. Piston-sensor design gives structural reliability in high-pressure use. Low-torque-control adjusting screw permits easy adjustment of pressures in closed or dead end systems.
Typical Applications
  • High-pressure testing
  • Purging and charging
  • Calibration kits
  • Airline charging carts
  • chemical plants
  • Manufacturing processes
  • Research and development
  • Laboratories
Model Configuration
Create your customized stock number by choosing one number from each of the three options in the chart below.
Example:  if you wanted a regulator with 0-2000 PSIG, with a stainless steel needle valve and with a CGA SS 347 inlet fitting, the stock number would be:  825 - 66 - 26
Option 1
Outlet pressure
  Option 2
Outlet Fittings
  Option 3
CGA Inlet Fittings - additional available
 823 0-500 PSIG   00 None    00 None
 824 0-1000 PSIG   66 Stainless Steel
needle Valve with
1/4" (6 mm) MPT
   08 CGA 540 (Oxygen)  3000 Max CGA
Inlet
Pressure
(PSIG)
 825 0-2000 PSIG        09 CGA 580 (Inert)  3000
 826 0-4000 PSIG        26 CGA SS 347  5500
 827 0-6000 PSIG         27 CGA SS 677  7500
         28 CGA SS 680  5500
         SS = stainless steel
