Resistance Spot Welding Tips
Always read and follow the safety precautions and operational instructions in your owner's manual.
| 1. Resistance welding is not recommended for aluminum, copper, or copper alloys. Use for steel and stainless steel only. |
| 2. For more heat (amperage output), use shorter tongs. |
| 3. For units without a heat control, tong length can be used for a control. For instance, for thin metals where you want less heat, longer tongs can be used. |
| 4. Keep in mind that longer tongs can bend, and you may lose pressure at the weld. |
| 5. For the metals being welded, make sure there is no gap between the pieces - this will weaken the weld. |
| 6. Keep the alignment of the tongs straight, so that the tips touch each other exactly. Also, maintain a proper pressure adjustment - not too much or too little pressure. |
| 7. When you need one side of the weld to have good appearance, you can flatten (machine) the tip somewhat on that side. |
| 8. Clean the tips on a regular basis, or you will lose output (amperage). Dress the tips with a proper tip dresser. |
See Also:
Handbook for Resistance Spot Welding (PDF)
Resistance Welding -
Printable
Version (0.05 MB, 0 min 7 sec at 56kb/s)
