#1
I recently purchased a Miller Dynasty 200DX
and want to practice welding thin aluminum. I figured welding beer cans would be good practice and the materials are cheap. The problem I'm having is that there are so many settings on the 200DX that I'm not sure where to set them all. It sure would be helpful if Miller included the recommended settings for various materials and thickness's in the owners manual and that they weren't generic but specific to the machine. I have their tig calculator but the 200DX has more settings than what are listed on the calculator. I've tried the lowest amperage setting and frequency set around 200 but I have to move excessively fast just to get it to not burn thru. Does anyone here have experience with welding something similar with a 200 DX and if so could you post all the settings as well as the tig rod size and tungsten size you are using? one more thing.....when im welding aluminum and dip the tig rod into the puddle, the outside of the tig rod is "gummy" when I take it out of the puddle. It stretches like gum and is quite irritating. Does anyone know how to cure this?
__________________
Millermatic 350P Dynasty 200Dx Hypertherm Powermax 1000 Victor Journeyman O/A Offshore Mill and Lathe Tunes to weld with by Peavey
#2
Here's one thread on the sister-board. I searched over there for "beer cans." A few threads have info, and this one had some specific settings you might try...
http://www.hobartwelders.com/mboard/...22beer+cans%22 |
#3
I cant help you with your settings, I dont run that machine myself. But as far as welding aluminum beer cans or anything of that nature I have gone back to gas welding using one of the new super alloys thats available. I wont **** any product here, but I can tell you that I have no problem welding any aluminum can or even filling holes up to 3/8" in diameter using mapp or propane fuel source. I know that even years ago we were welding cans togeather using the old tig technology, I am sure with your new machine once you get your settings dialed in, you will be able to weld as many beer cans togeather as you wish, providing you are not trying to consume the contents as fast as you weld the cans.
#4
Thanks for the link Mac
, I'm sure it will come in handy and I will have a look at it tonight.Thanks for the post Dan I'm not really trying to weld any aluminum for a specific purpose other than tig practice. I can't promise I won't sample the contents while practicing but don't worry, there aren't too many structural beer can towers out there and I wasn't planning on making one, but if I do I'll try to limit it to 3 floors
__________________
#5
I assume you mean dip the tig rod[filler metal] in the puddle. I think it does that because there is not enough heat in the puddle to melt the filler rod. I do it too sometimes. maybe use the smallest filler rod. I think .040". haven't tried a beer can yet but will with my 180sd. If i can do it with that i know you can do it with the dynasty, you even have pulse with that machine which should let you weld even thinner stuff. Let us know how you make out and I'll post it when I try it.
__________________
Scott HMW [Heavy Metal welding] |
#6
Thanks for the reply HMW.
Yes, i was refering to the tig filler rod. It is quite possible I didn't have enough heat in the puddle as I was using the lowest setting on the 200DX. I will have to try it again with a bit more amperage and some smaller rod. I was using 3/32 filler because that was all I had. I'm sure the machine itself is more than capable of welding the beer can, I just have to learn to use it properly
__________________
#7
I know you can get 1/16th. I have some of that. I also used some .035" out of my spool gun once. It worked. Sometimes I use smaller filler than you need just because its easier to work with. Uses up more filler rod but sometimes only have short weld to make anyway. good luck with your new machine
__________________
#8
i think i would drop that back a bit and let the arc widen up a bit, it should help stop the burn threw. i think i would rip a lil sidding off the house (provided its aluminum sidding) and practice on it first then move on to beer cans. naybe hit the good will store and buy a old set of aluminum crutches to play with. finding stuff to practice on is easyer than you think you just gota think of every thing as matereal insted of item, just look at what it made of not what it is.
__________________
thanks for the help ......or.......... hope i helped feel free to shoot me an e-mail direct i have time to chat. james@newyorkmetalart.com summer is here, plant a tree. if you don't have space or time to plant one sponsor some one else to plant one for you. a tree is an investment in our planet, help it out. ![]() JAMES |
#9
I have done this on Pepsi cans with a Miller Econotig machine on low setting and using 1/16" filler rod and 3/32" pure tungsten. It helps to clean cans with a stainless steel wire brush to get the coating off.
#10
Hey Tek, can I assume you're drinking the contents of the aforementioned cans? Stay away from Old Style or Millers- bad aluminum! I know you folks up north don't celebrate the 4th of July, but have a great day anyway!
__________________
Dynasty 200DX Lincoln SP135 Plus Victor O/A outfit Dewalt chop saw |
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
