  #1
Old 08-24-2008, 08:43 AM
jamscal jamscal is offline
Default Homemade press brake
Here's a few pics. I make among other things off-road bumpers.
Previous method of making bumpers included cutting every plate and welding the seams. Now I can bend at least some of the joints, making things easier on me, and the bumpers smoother.
The design is basically the same as the Northern Tools version, and there are people on ebay who make the same design.
I had the die springs and some of the steel, I think I'm out less than $40 for the whole thing.
Also pictured is a piece of 3/16" plate bent up.
  #2
Old 08-24-2008, 11:24 AM
aametalmaster's Avatar
aametalmaster aametalmaster is offline
Send a message via Yahoo to aametalmaster
Nice job...Bob
__________________
http://groups.yahoo.com/group/ornamentiron/
http://groups.yahoo.com/group/southbend10k/
http://www.ceilingtrains.com/
http://www.osha.gov/SLTC/hexavalentchromium/index.html
  #3
Old 08-24-2008, 08:46 PM
Geezer Geezer is offline
Default Homemade Press Brake
Looks good and evidently plenty functional.
Is the center a piece of heavy angle to form the bend? Reason I ask is I cut a 1 inch piece of metal to a point (3/16" flat at the point) and plan to make a brake for my 20 ton press. If you have a different/better approach I would be interested before I finish.
Appears Nothern uses a piece of angle iron. Am I reading this wrong?
thanks,
Geezer
  #4
Old 08-25-2008, 06:18 AM
I know some people use heavy angle.
My upper die is a piece of 1/2" thick crs with an edge gound on it. Mine also has a land or flat on the edge.
I like this way because I can regrind at anytime as it wears. Angle will eventually need to be replaced.
Also, with angle, the bend will stop at 90 degrees, and you need to go a bit more with some materials to get that full 90 to account for springback.
-James
  #5
Old 08-25-2008, 07:32 AM
Thanks James, my upper die is a piece of 1 inch just because thats what I had.
I am still not quite understanding what you used for a lower die. That was where I planned to use angle.
Do you just have two horizontal pieces welded to the bottom frame with a space in the middle as a bottom die? If so what are their demisions? sorry, the penny has not dropped yet.
  #6
Old 08-25-2008, 08:54 AM
I was experimenting with the lower die.
I have two pieces of 3x4 square stock welded...maybe an 1 1/2" apart, to the plate. Then I have two pieces of 1/2" round stock that fits inside of that. I used tig rod to tacked on the ends to keep them against the square.
This is removable if I need to replace them or move to a different shape or size.
I posted the above pic over at the HSM site, and there is a link someone posted to the appropriate dimensions for such work. I'll find the link soon.
I cna take pics if the above is a poor explanation.
Thanks,
James
Edit: Link
http://bbs.homeshopmachinist.net/showthread.php?t=30387
  #7
Old 08-25-2008, 05:16 PM
may I send you a PM
  #8
Old 08-25-2008, 05:21 PM
Quote:
Originally Posted by Geezer View Post
may I send you a PM
Sure, and I'll try to get some more detailed pics on here later.
-James
  #9
Old 08-26-2008, 07:03 AM
PM sent last night
  #10
Old 08-26-2008, 07:22 AM
Here is a more detailed pic.
I have the plate, and two 3/4" bars welded to it approx 2" apart.
Then I have two 1/2" pieces of round stock I stuck in between there to get the proper opening.
I did this because this was an experiment and I knew I could change out the round for a smaller or larger diameter if necessary, and also, replace if they wear out.
I'm sure there are other ways to do it, but so far this has worked for me.
And after I posted this, I noticed two (I think) homemade press brakes in the projects section of this site.
-James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Please read our Terms of Use. The success of this Forum requires each and every person to adhere to the rules and policies. Messages that harass, abuse or threaten other members; have obscene or otherwise objectionable content; have spam, commercial or advertising content or links may be removed and may result in the loss of your posting privileges. Please do not post any private information unless you want it to be available publicly.
Feedback/Help - Miller Welding Discussion Forums - Archive - Top
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
