Go Back   Miller Welding Discussion Forums > Welding Projects
Reply
Thread Tools Display Modes
  #1
Old 06-01-2007, 12:41 PM
subzero subzero is offline
Question What's the best way to weld copper?
I have a few projects planned where I will need to weld copper to copper. Some copper pipe, and some copper sheet metal. These projects will need strong welds, I also dont want a brass look where the weld joints are, like sweating in plumbing. I am looking into patina or burnt copper finish when I am done, so it has to look good, I can grind down a weld with no problems if the process doesn't add another metal type that will show through and ruin the look I am going for. I appreciate any and all comments!
__________________
- 250 Bobcat
- too many irons in the fire
  #2
Old 06-01-2007, 01:06 PM
Fat-Fab.com's Avatar
Fat-Fab.com Fat-Fab.com is offline
GTAW and lots of amps and for filler use the same material as the parent material
__________________
  #3
Old 06-01-2007, 01:59 PM
fun4now's Avatar
fun4now fun4now is offline
yep TIG it, just remember it sucks up the heat so you will need big amps for any thing thick. how thick is the copper you intend to do?? if its realythick you might need to go to plasma welding it.
__________________
  #4
Old 06-01-2007, 02:45 PM
One project is sheet metal, haven't bought it yet so don't have the thickness. The other is copper plumbing pipe.
I have access to a Miller 175 Mig. Is there any way to use that for this project?
I saw on mw.com where this welder is capable of copper welding. Someone told me that I could weld copper w/ the 175, but would need a spool gun to do it.
Thanks for the input!
__________________
- 250 Bobcat
  #5
Old 06-01-2007, 03:35 PM
Aerometalworker's Avatar
Aerometalworker Aerometalworker is offline
I doubt the cabability of the 175 for what your needing.
If you dont have a TIG, gas weld it using copper filler and flux, its used a lot for ornamental copper work and copper pressure vessels.
www.tinmantech.com is a good source for materials and further information.
-Aaron
__________________
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
  #6
Old 06-01-2007, 03:37 PM
MAC702 MAC702 is offline
GTAW with a piece of the actual parent metal to use for filler is the best way to achieve the perfect finish you are looking for.
  #7
Old 06-01-2007, 08:54 PM
phila.renewal phila.renewal is offline
TIG it DCEN with deoxidized copper filler. Don't use bare electrical wire or plain copper -- the welds will come out like crap. Deoxidized copper filler is not hard to find.
I confess that I have never done it . . . at least successfully . . . but I have seen it done and it works.
Also, copper needs lots of heat. Don't be shy with the amps.
Good luck with it and post pics.
  #8
Old 06-01-2007, 09:28 PM
dabeldesign's Avatar
dabeldesign dabeldesign is offline
I like silica-bronze filler to Tig weld copper. It's easy, gives you a clean finish, and it's strong. I'm not sure about patina finishes on it though.
But then again, it sounds like you don't have a tig welder. O/A torch would be my next choice...
  #9
Old 06-01-2007, 09:52 PM
TS-Off-Road's Avatar
TS-Off-Road TS-Off-Road is offline
You can get silicon-bronze mig wire and with 100% argon you can mig braze it. Daytona Mig has 2lb spools of .030 s/b wire for around $30, 10lbs for $140.
Not sure if you need a spool gun to use it like you do with Al.
  #10
Old 06-01-2007, 10:15 PM
How will the final finish turn out compared to the properties of the parent weldment?
You shouldn't need a spoolgun. Silicon Bronze wire is much stiffer than aluminum.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Please read our Terms of Use. The success of this Forum requires each and every person to adhere to the rules and policies. Messages that harass, abuse or threaten other members; have obscene or otherwise objectionable content; have spam, commercial or advertising content or links may be removed and may result in the loss of your posting privileges. Please do not post any private information unless you want it to be available publicly.
Feedback/Help - Miller Welding Discussion Forums - Archive - Top
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
