#1
Hi guys, I'm on the site alot reading , but never posted much. I've been around drag racing for many years now and also race. I do some tig welding in my home shop, have a dedicated grinding wheel for my tungstens and sharpen them vertical to the wheel. I've been in alot of chassis shops (some well known) and see the tungstens held horizontal to the belt sander. The same belt sander they use to debur, remove chrome moly, mildsteel etc. and their welds come out beautiful. Here's the question, what's the right way and does it really matter.
#2
I'm a little curious too, i have alays sharpened mine along the length with a belt sander or diamond wheel. recently i started a TIG class and the instructor sharpens his on a grinding wheel that is not dedicated, he uses a slight angle from parallel and has clear spirals. Another welder who is a certified AC welder with over 40 years of experience showed my friend the same technique and makes his point slightly convex. They both use a very long taper. I have always gone by the Miller/diamond ground reccomendations. I wonder if there is any advantage to each method.
__________________
Dynasty 200 DX Millermatic 175 Spectrum 375 All kinds of Smith OA gear |
#3
We've always used a bench grinder to sharpen the tungsten, personally I point my tungsten up into the wheel, resting my hands on the table, I also use a twist drill holder to grip the tung. and rotate it.
I like to take mine to a fairly decent needle point, also when sharpening with the point "up" into the wheel the material removed goes away from the finished point instead of down and collecting on the point if you held the tung. down. Holding the tung. level/ perpendicular to the wheel is the way I use to do it, but I found I could do a better job vertically.
__________________
pull-do |
#4
The text book answer is grind it in the direction of the rod not perpendicular to the rod.
But it comes down to this One is the grit of the abrasive you are using. Too course will foul things up either way you grind it. so if there is a fine enough abrasive it wont matter much. Then there is the matter of what you are welding and how many amps you are using. The more power put through the tungsten the less the grind matters. Either way I use a bench grinder and grind it like the book shows, Inline with the rod and always finish it up on the fine wheel.
__________________
Miller Syncrowave 200 W/Radiator 1A & water cooled torch Miller X-treme 12VS wire feeder Bridgeport Mill, South bend lathe 10LX40 K.O. Lee surface grinder 6X18 Over 19 years as a Machinist Toolmaker A TWO CAR garage full of tools and a fridge full of beer ![]() Auto shades are for rookies ![]() |
#5
I am ready to get a freakin' Sharpie. I spend way to much time grinding my tungsten.
I guess I don't have a steady enough hand but it's been years since I last sat at a table.
__________________
Miller Maxstar 200 DX RMLS-14 Momentary Hand Control Miller Syncrowave 180 SD Porter Cable 14" dry metal saw Hitachi 4.5" grinder http://theconcreature.com |
#6
Here is my take on tungsten grinding technique...the shape matters more than the method.
Once you get so good that the only area you could improve your welds is the little inconsistencies in your tungsten surface then you would be wise to spend your time on that. I have laid down some of my best beads ever, that nobody will ever see, using a 4 1/2" grinder loaded with aluminum with one hand and tungsten in the other because I was simply too wore out to crawl out from under the boat on a trailer and use a better method. SAFE? NO! PERFECT SHAPE? NO! BUT... perfect enuff to get done and get paid
__________________
Miller Dynasty 700...OH YEA BABY!! ![]() MM 350P...PULSE SPRAYIN' MONSTER ![]() Miller Dynasty 200 DX "Blue Lightning" ![]() Miller Bobcat 225 NT Miller 30-A Spoolgun Miller WC-115-A Miller Spectrum 300 Miller Spoolmate 200 Miller 225 Thunderbolt |
#7
http://millerwelds.com/education/tec...ps/setup.html\
There information is itself on this site you just need to look for it. I myself have a wheel that all it is for is shaping nothing more. Vert or horiz. Makes a big difference when your welding AC in my experience DC its makes a difference but for myself not noticeable. For the guys using Flapper wheel or belt sander you stop preppin your welding material as well cause your loading your tung with what ever is on the belt of flapper so why put forth the effort for a clean weld when you cant go the extra step in your tung prep. |
#8
Quote:
and not everybody is willing to pay you to screw around with laying perfect beads. They just want it to be welded strong and look reasonably well at a reasonable price.There are many times I have gotten everything absolutely perfect only to dip tungsten right off the bat ![]() I can get as persnickity as anybody...but....I only get paid for the jobs I finish. I normally sharpen both ends of my tungsten in a cordless with a dedicated bench grinder btw. I still have a ton of work from as far back as November left to do. Every stinkin' time the sun shines my phone goes crazy. My customers LOVE my dirty unprepped welding ![]() Truth is if I could weld things and make them look as tho they had NEVER been welded (ie undisturbed patina) I could charge a bunch more
__________________
#9
Quote:
PICS! PICS! PICS! PICS!
__________________
I'm not late... I'm just on Hawaiian Time |
#10
Quote:
__________________
Previous Thread
Next Thread
| Thread Tools | |
| Display Modes | |
Linear Mode
