  #1
Old 03-28-2008, 05:35 PM
lifeofwelding lifeofwelding is offline
Default Welding mild steel to chromoly?
Does anyone know how this works out? any special filler rods needed? Any other special needs for this process?
Shawn
  #2
Old 03-28-2008, 06:13 PM
kcstott kcstott is offline
Works fine just don't expect the mild steel to do the work that the chromoly should be doing. You may run into the weld cracking due to the lack of similarities between the two metals but over all it's fine.
Filler rod is not a big issue but it would help if you use a chromoly rod
What is it exactly you are doing?
__________________
Miller X-treme 12VS wire feeder
Bridgeport Mill, South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Over 19 years as a Machinist Toolmaker
Auto shades are for rookies
  #3
Old 03-28-2008, 06:34 PM
Im building a mini dune buggy. I wanted to make the frame out of 4130 and all the mounts from mild steel. I was curious as to how the mounts will work since they arent the same type of metal.
  #4
Old 03-28-2008, 09:33 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
http://www.aws.org/wj/apr03/AWfeature.html
Some info
  #5
Old 03-28-2008, 10:35 PM
If in "mounts" you mean engine mounts, shock, axle, steering mounts. Sure I've done it for a few friends with buggies. Weld prep the heck out of them and burn them in. I've used a mig every time and that seems to be the best way.
Just be sure your mounts are either prefabed (store bought) or are stout enough where needed. Overkill is a good thing in this aspect
__________________
  #6
Old 03-29-2008, 01:08 AM
Laiky Laiky is offline
mild steel rod NOT chromoly rod, er70s2 or 6, do a search and you will find all the 4130 info you need.
__________________
Dynasty 200 DX
Millermatic 175
Spectrum 375
All kinds of Smith OA gear
  #7
Old 03-29-2008, 07:48 AM
Quote:
What he said yeah yeah that's it. Guess I should have been more specific.
Yes mild steel filler is fine for welding mild steel mounts to 4140 4130 tube
__________________
  #8
Old 03-29-2008, 01:26 PM
Broccoli1's Avatar
That's the info in the Link I posted
  #9
Old 03-29-2008, 01:30 PM
Blue Collar Moto's Avatar
Blue Collar Moto Blue Collar Moto is offline
Actually I think the chromoly will crack before the mild steel. The moly is stronger but at the welded joint without pre and post heat can be verry brittle after welding. About 1/4" away from the weld will be the weakest spot. (assuming your using 1 1/2 tubing) Im sure theres alot of people on here that know much more about this than I do. Just my .o2
__________________
Beans for breakfast once again.
  #10
Old 03-29-2008, 07:53 PM
Yes this is true but on small pieces for what ever reason pre and post heat is not used and works fine. Is this to say that pre and post heating would not help?? No just that it almost makes no difference with the kind of loads these parts will see. and it just plain not practical to pre and post heat a buggy frame. lots of little flanges and pieces that need to be attached by the time you pre and post heated one part you could have had half of them done. This is also why a lot of the mounts are made from 5/16" 3/8" and up to 1/2" and bigger plate. once again OverKill but it get the job done.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Please read our Terms of Use. The success of this Forum requires each and every person to adhere to the rules and policies. Messages that harass, abuse or threaten other members; have obscene or otherwise objectionable content; have spam, commercial or advertising content or links may be removed and may result in the loss of your posting privileges. Please do not post any private information unless you want it to be available publicly.
Feedback/Help - Miller Welding Discussion Forums - Archive - Top
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
